Asus LCD BL on/off
    Asus LCD BL on/off
    Asus X302LA:
    With AC (with or without BATT) the LCD BL BACK LIGHT is ON
    If I remove the AC adapter the lcd go off but the system remain on
    AC+BATT BATT
    L_BRIGHTNESS_C Y Y
    BL_EN_C Y Y
    +3V_EDP Y Y
    +LED_VCC_INV 19V 7.9V
    BIOS reprogrammed, EC no reprogrammed
    Re: Asus LCD BL on/off
    Hi
    Try another display to Test
      measure +LED_VCC_INV on a healthy laptop when power is provided by battery only.
        On some other Asus models, the faulty component is a coil on LCD panel board. So either changing that or LCD panel should fix this issue.
          thanks,
          you reminded me of a similar problem a few years ago.
          I had solved it by changing the coil.
            +1
