Issue reading Macronix BIOS-chip in HP Elitebook
  • ValleyDude2605
    • Jun 2020
    • 7
    • The Netherlands
    Hi, I'm trying to revive an HP Elitebook 840 G2 with a bricked bios. Problem is that I'm stuck on getting a dump from the BIOS-chip, it doesn't seem to give me the correct output.
    I'm using a Raspberry Pi 2B+ with Flashrom and a Pomona SOIC8-clip. The chip in question is a Macronix MX25L12873F (datasheet here). Flashrom detects the chip fine - or so it seems, it's detected as a "Macronix MX25L12835F/MX25L12845E/MX25L12865E". Reading takes quite long, I'd say about ten minutes or so. When I open the output in a hex-editor every line is like this:
    Code:
    C2 20 18 C2 20 18 C2 20 18 C2 20 18 C2 20 18 C2
    Does anyone have an idea why this is, and what I could change to get a correct dump of the BIOS?
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Issue reading Macronix BIOS-chip in HP Elitebook
    Desolder the chip.
    • ValleyDude2605
      • Jun 2020
      • 7
      • The Netherlands
      Hi piernov, thanks for your reply. It's that simple? Desoldering will make it able to read the chip?
      Unfortunately that's not really an option for me right now, I have to do it in situ. And I've seen plenty of posts and videos online where it worked, so I'm just baffled why I keep getting stuck on getting a correct dump.
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Not all programmers are able to work with the soldered chip.
        With the chip soldered, it is possible that the power supply or some signals are attenuated by the connection with the motherboard.
        As he cannot read it correctly he will certainly not be able to program it. For the dump you can find it in the bios section or you can request it.
        • KingBonecrusher
          • Jun 2020
          • 28
          • Netherlands
          Try this:
          1) disconnect battery & ac
          2) connect programmer
          3) connect ac (ONLY AC!)
          4) read eeprom
          • ValleyDude2605
            • Jun 2020
            • 7
            • The Netherlands
            Thanks for the feedback, but I'm afraid I'll have to give up on this project. I tried nearly everything:
            - different programmers (RPi, CH341A Black, CH341A Blue)
            - different voltages (no GND+VCC, 3V3, 5V)
            - Elitebook not powered on, Elitebook connected to AC but not powered on, Elitebook powered on
            Guess I'm out of options here.
            • RethoricalCheese
              • Mar 2013
              • 1518
              • Estonia
              Raspberry can always read soic8 HP bios without desoldering but it takes a certain action first. In your case, you are not able to do that because your machine does not post. Thus you need to desolder.
              Btw, use the command
              Code:
              flashrom -p linux_spi:dev=/dev/spidev0.0[B],spispeed=10000[/B]
              10000 is quite fast and reliable. 20000+ might have issues with some chips.
              Default is only 1000 if I am correct.
              • ValleyDude2605
                • Jun 2020
                • 7
                • The Netherlands
                Thanks @RethorialCheese, I will give it another try then.
                Perhaps this is a dumb question, but you say that I can't read the chip because the machine does not post. But if I desolder, then there is no post either, right? Or is that the difference between reading/flashing in situ and doing it with a desoldered chip?
                • Bonzas
                  • 471
                  • Indonesia
                  AFAIK your chip is 1,8v, you need 1,8v converter.
                  you may be able to read and backup file from these chip but u'll got error when verifying file after flash. so far, i always failed when reprogram bios without desoldering chip from motherboard
                  • ValleyDude2605
                    • Jun 2020
                    • 7
                    • The Netherlands
                    According to the datasheet this is a 3,3V chip.
                    • RethoricalCheese
                      • Mar 2013
                      • 1518
                      • Estonia
                      HP EliteBook, Probook and Zbook always use 3.3V chips.
                      If the machine posts and you turn it off but leave charger connected, it will be in a state where you have no problems reading with raspberry. If you desolder, there aren't any other parts disturbing. So either post and shut down to read on board or just desolder.
                      • Bonzas
                        • 471
                        • Indonesia
                        Ah my fall, sorry i didn't see your attachment. There 25U have 1,8v not 25L
                        • ValleyDude2605
                          • Jun 2020
                          • 7
                          • The Netherlands
                          This actually seemed to do the trick! I booted, shut down and then tried to read the chip with success. I did four reads, just to be sure, and they all checked out to be exactly the same. Removed the BIOS-password and reflashed the BIOS, all good to go now.
                          Next project: fixing the "ME state in recovery mode" error.
                            HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:50 AM
                            HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 650 15.6 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 650 15.6 inch G9 Notebook PC boardview and EliteBook 650 15.6 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-07-2024, 05:20 AM
                            HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
