Toshiba A200 Equium 6050A2109401-MB-A02 dead no power
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Toshiba A200 Equium 6050A2109401-MB-A02 dead no power
    Originally posted by Motherfinboard
    Some components are getting warm as soon as I plug in DC,without even pressing power button. Components near dc in and the copper heatsink pipe.
    if components are getting hot you having a short in the MB what are the Components getting hot uplode a pic of the area ?
    check the resistance to gnd R523 with out power ?
    what voltage you get Q503 Source side ?
    check U500 pin 2 3 4 5 12 voltage be care full don't short the pins ?
    find out the voltage on L12 & L18 coil voltage page 7 Schematic?
    • Motherfinboard
      • May 2020
      • 68
      • United Kingdom
      Getting hot around D502,Q504 jumper wire,fuse501,L500,C532,R523 and capacitors around it.
      Also other side of board warm inside red circle.
      R523= 3.5 omhs Q503= 2.3v
      Pins on U500, 2= 2.9v 3= 2.9v 4= 3.0v 5 = 187v 12= 2.73
      L18= 20.5v L12= 0.5v
      • Motherfinboard
        • May 2020
        • 68
        • United Kingdom
        Results of short to ground with jumper wire removed.
        Q504 drain stg,fuse501 no stg,c504 1pin stg,c503 1pin stg,
        D502 no stg,c532 1 pin stg,c524 no stg,R521 no stg,
        L500 no stg,R523 2 pins stg,c538 2 pins stg,
        c534 2 pins stg,c533 2 pins stg.
        Cheers Olly
        • Motherfinboard
          • May 2020
          • 68
          • United Kingdom
          Hi, I have 096.7 kilo ohms on pin 1 and 25.75 kilo ohms on opposite pin of L506,after rechecking with black lead to ground red lead to the pins on L506.
          I wonder if this is correct still attached to board no power connected?
          Thanks Olly
          • Motherfinboard
            • May 2020
            • 68
            • United Kingdom
            Pictures of the parts soldered back onto board with changed n channel.
            • Motherfinboard
              • May 2020
              • 68
              • United Kingdom
              #26
              I now have a blue light when plugging in ac adaptor,but still no fan spin when pressing power button?
              Anyone have any idea where I can check on the board next please.
              • Motherfinboard
                • May 2020
                • 68
                • United Kingdom
                #27
                So I have lifted 1 pin on each of L513,L516 and still only a blue light doing anything from the board,CPU fitted and without CPU.
                Can anyone confirm I have the cable connected from the board to power button is fitted the correct way on both ?
                Thankyou
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  #28
                  Cable is reversed, it won't make contact with the connector pins.
                  Also no point in messing with the CPU inductors, but would be a good idea to replace the NEC Tokin.
                  • Motherfinboard
                    • May 2020
                    • 68
                    • United Kingdom
                    #29
                    Reversed both ends so blue tab down?
                    It's what another member recommended to lift the conductors as his tried helping me from the start.
                    • Motherfinboard
                      • May 2020
                      • 68
                      • United Kingdom
                      #30
                      I now have fan spin and 2 blue lights on with AC adaptor. L513 L516 soldered back to board are both showing 0.988v with power on?
                      Doesn't seem to be correct voltage to me.
                      Still have a black screen too.
                      Cheers
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        #31
                        Voltage is correct for that line now check again all coils what voltage is missing
                          • 22115
                          Could be the NEC tokin cap as piernov suggested ?
                          • Motherfinboard
                            • May 2020
                            • 68
                            • United Kingdom
                            #33
                            If it is the NEC Tokin,do you know which 4 replacement chips to use so I can try.
                            Cheers
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              #34
                              Use 330uF SMD aluminum polymer capacitors from the CPU VCore section of a donor board.
                              • Motherfinboard
                                • May 2020
                                • 68
                                • United Kingdom
                                #35
                                Here is test of all coils,well I think all coils.
                                L513=1v ,L516=1v, These to are getting hot?. L503=1.10v, L501=193v not good?. L25=1.25v, L18=5.16v, L12=3.4v, L2=1.87v, L506=19v, C532=19v, L500=19v.
                                Cheers
                                • Motherfinboard
                                  • May 2020
                                  • 68
                                  • United Kingdom
                                  #36
                                  Not changed the Tokin chip yet.
                                  I am getting fan spin,blue light for power and also charge/power light and it also charged the battery. I connected the com port to TV, but black screen issue still present,and hdd not spinning up. Ram tested and seems ok.
                                  Does it now point the the Nec Tokin chip as the problem?
                                  Cheers
                                  • Motherfinboard
                                    • May 2020
                                    • 68
                                    • United Kingdom
                                    #37
                                    Can the bios battery measuring only 0.3v on the board stop the screen and hdd booting or because I have power it cannot be the battery.
                                    • Motherfinboard
                                      • May 2020
                                      • 68
                                      • United Kingdom
                                      #38
                                      Can anyone suggest anything else to get picture on the screen before I bin this board.
                                      Should I replace the NEC tokin first then try again or worth trying a reheat of gpu to see if it may show picture,even if it's a temp fix at least I know it was the gpu then.??
                                      Last chance for this Toshiba now,had enough of it!
                                      • piernov
                                        • Jan 2016
                                        • 4439
                                        • France
                                        #39
                                        Yes low coin cell battery can cause issues.
                                        I don't see a dedicated GPU on this board.
                                        • Motherfinboard
                                          • May 2020
                                          • 68
                                          • United Kingdom
                                          #40
                                          I have this smaller blue type battery, is it still 3v and does it have to have be blue seal surrounding it. Not very popular to find.
                                          Isn't the graphics chip next to the cpu socket?
                                            Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                            Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                            Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                            Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
