Toshiba A200 Equium 6050A2109401-MB-A02 dead no power
  • Motherfinboard
    • May 2020
    • 68
    • United Kingdom
    Hi all, I have dug this laptop out of storage,it refused to switch on.After getting out of storage i tried to power on again with DC adaptor,power light came on and battery charge light to but no system boot, fan etc and after about 1 minute everything went dead,and since not able to get power again.
    Took out the motherboard and have 19v on DC connection and i could hear a faint clicking noise. I have 19v upto mosfet Q504 on the schematic. Then 19v on 4 of the pins and 35v on other 4 pins. From there on R523,C522,C528 and C529 where I stopped testing i had 35v. I'm guessing 34v is to high here but not sure how to read schematic to tell me what voltage I should have on these components.
    Any help appreciated thanks.��
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Toshiba A200 Equium 6050A2109401-MB-A02 dead no power
    35V on Drain side of Fet Q504 is too high do you have another adapter to test ?
    More than +20V is too high, you have to test the Fet for any short
    • Motherfinboard
      • May 2020
      • 68
      • United Kingdom
      I was thinking the same with 35v. Only one power adapter,tests ok with voltameter. What could the adapter effect if I am getting the 19v? as it's original Toshiba power supply
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Are you familiar with testing SMD components with a multimeter? Can you remove the Fet Q504 and tested out of the MB, Do you have a solder gun? If you’re getting 19V from the adapter that should be fine, there’s a way of by passing the voltage but need info ,Upload a picture of that area
        • Motherfinboard
          • May 2020
          • 68
          • United Kingdom
          I have power adapter connected only.My multimeter red on ground screw and black touching pins,correct?.
          On Q504 mosfet no short to ground,but on Q506 mosfet I think it is,I have 2 pins next to each other showing 0v other 2 pins 36v. Opposite side 0.4v on 4 pins.
          Thanks again.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            First check your multimeter's battery. Getting 35V is bit wierd.
            • Motherfinboard
              • May 2020
              • 68
              • United Kingdom
              Are you familiar with testing SMD components with a multimeter? Can you remove the Fet Q504 and tested out of the MB, Do you have a solder gun? If you're getting 19V from the adapter that should be fine, there's a way of by passing the voltage but need info ,Upload a picture of that area
              High yes confident to do all as said,photo uploaded.
              Will check my battery in meter but I'm sure it's ok.
              • Motherfinboard
                • May 2020
                • 68
                • United Kingdom
                Battery fine in meter too
                • Techtiger
                  • Oct 2014
                  • 1601
                  • france
                  what is the output voltage only the battery terminals remove the adapter and power with battery? voltage on all legs of Q503 ? clean top of the U500 & Q503 uplode pic again I see a hole on top of the Q503 but not sure, you need the test Q504 Q504 with multimeter in DIODE mode we need the readings if not sure how to test check Youtube how to test P-Channel fet
                  • Motherfinboard
                    • May 2020
                    • 68
                    • United Kingdom
                    Cleaned board again,see pic
                    • Techtiger
                      • Oct 2014
                      • 1601
                      • france
                      That's fine now come up with the voltages
                      • Motherfinboard
                        • May 2020
                        • 68
                        • United Kingdom
                        Battery attached I have 0v on six of the pins and 0.3v on last three pins together. Battery has not been charged for a few years tho.
                        Q503, 0v on all pins with battery attached . Ohms on Q503, 4.3 on all four drain side with battery and black lead in source red on drain.
                        Q504 ohms with battery attached are 2.3 on all four drain pins wires and battery connected as above.
                        • Techtiger
                          • Oct 2014
                          • 1601
                          • france
                          you have to test with out any power test again ! , do you solder iron to remove Q504 if so remove and put a jumper from pin 123 to 5678 & uplode a pic before power up
                          • Motherfinboard
                            • May 2020
                            • 68
                            • United Kingdom
                            Oh I thought you meant leave battery connected while checking ohms too🙄.
                            Will recheck the ohms on q504,then I might need a day or two to get to use my soldering iron etc,as they are not currently at my house and will report back.
                            Thanks for the advice,you seem the only one who can help at the minute
                            • Motherfinboard
                              • May 2020
                              • 68
                              • United Kingdom
                              If I did the test correct this time I have 2.3k ohms on drain side of mosfet Q504 still on the board atm.
                              • Motherfinboard
                                • May 2020
                                • 68
                                • United Kingdom
                                Hope this is good enough,only had this thick wire atm. All good to power up? Thanks
                                • Techtiger
                                  • Oct 2014
                                  • 1601
                                  • france
                                  Ok power up MB with out battery instead
                                  • Motherfinboard
                                    • May 2020
                                    • 68
                                    • United Kingdom
                                    Hi,Getting nothing no power.
                                    • Motherfinboard
                                      • May 2020
                                      • 68
                                      • United Kingdom
                                      Some components are getting warm as soon as I plug in DC,without even pressing power button. Components near dc in and the copper heatsink pipe.
                                      • Motherfinboard
                                        • May 2020
                                        • 68
                                        • United Kingdom
                                        Hi techtiger or anybody else,any idea where to look now on the board,and do I need to solder mosfet back on the board,or is the mosfet bad.
                                        Thankyou
                                          Toshiba Satellite Pro A200-1MV Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1MV can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1MV boardview and A200-1MV schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro A200-1KQ Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1KQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1KQ boardview and A200-1KQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1K4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1K4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1K4 boardview and A200-1K4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-1H4 Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-1H4 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-1H4 boardview and A200-1H4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                          Toshiba Satellite Pro A200-16B Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro A200-16B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A200-16B boardview and A200-16B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
