iMac (21.5‐inch, Late 2013) 820-3588-A
  • poldo
    • Mar 2020
    • 33
    • italia
    Ciao a tutti...I hope to be in the right place,
    the car in question is:
    Model Number: A1418
    EMC Number: 2638
    Speed: 2.7 GHz
    Type: Intel Core i5 (4th Gen) (Crystal Well) Model: 4570R
    Cores: 4
    Graphics Card: Intel Iris Pro 5200
    The problem lies in the logic board Model Number 820-3588-A
    Symptom:
    started correctly then suddenly went out. If I leave it off for several hours and then try to start it, LED 1 lights up then LED 2 then goes off after 10 seconds (photo01) and if I try again, only LED 1 lights up for a second (photo02) and that's it.
    I have two tested and operated power supplies but the problem persists.
    Any advice will be well received.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: iMac (21.5‐inch, Late 2013) 820-3588-A
    Still sounds like a power supply issue so confirm your power supplies are still working with another main logic board if possible.
    If it is indeed a main logic board issue, measure voltages on the G3H and S5 power rails listed on page 70 of the schematics.
    • poldo
      • Mar 2020
      • 33
      • italia
      Photo...
      • poldo
        • Mar 2020
        • 33
        • italia
        Hi Piernov,
        then not only alone, thanks for listening to me.
        I used two power supplies and both tested on a working iMac.
        G3 Rails
        PP3V3_G3
        -------- PP3V3_G3_RTC 3.2V
        -------- =PPVRTC_G3_PCH 3.2V
        G3H Rails
        PP12V_ACDC
        ---------- PP12V_G3H_ACDC 12V
        ---------- =PP12V_G3H_SNS_R 12V
        PP12V_G3H
        --------- PP12V_G3H_SNS 12V
        --------- =PP12V_G3H_REG_3V42_G3H 12V
        --------- =PP12V_G3H_FET_P12V_S0 12V
        ---------- =PP3V3_G3H_SMC
        ---------- =PP3V3_G3H_RTC_D 3.40V
        ---------- =PPVIN_G3H_SMCVREF 3.40V
        ---------- =PP3V3_G3H_SMC_USBMUX 3.40V
        ---------- =PP3V3_G3H_LPCPLUS 3.40V
        • poldo
          • Mar 2020
          • 33
          • italia
          S5 Rails
          Enabled when system has AC and is in S5
          PP12V_S5
          -------- PP12V_S5_FET
          Q6970 OUT 0.324V
          -------- =PP12V_S5_REG_P3V3P5V_S5
          C7610 0.324V
          -------- =PP12V_S5_REG_VDDQ_S3
          C7310 0.324V
          -------- =PP12V_S5_PWRCTL
          C8430 0.324V
          -------- =PPHV_SW_TBTAPWRSW
          C3210 0.324V
          -------- =PPHV_SW_TBTBPWRSW
          C3310 0.324V
          -------- =PP12V_S5_SNS
          R5401 0.324V
          PP5V_S5
          ------- PP5V_S5_LDO
          C7601 0.030 FLOATING rising
          ------- =PP5V_S5_PWRCTL
          C8400 0.033V
          Q7600 pin4 0.033V
          R7601 0.033V
          PP5V_S5
          ------- PP5V_S5_LDO
          C8400 0.033V
          Q7600 pin4 0.033V
          R7601 0.033V
          • poldo
            • Mar 2020
            • 33
            • italia
            I specify that these measurements are made exclusively with the power supply and logic board but the LEDs are inactive.
            • piernov
              • Jan 2016
              • 4439
              • France
              Measure voltage on SMC_PM_G2_EN.
              Measure resistance to ground on PP5V_S5_LDO, PP3V3_S5 and PP5V_S4.
              • poldo
                • Mar 2020
                • 33
                • italia
                SMC_PM_G2_EN
                measurement performed on PIN2 of the U6970 is 3.4V
                PP5V_S5_LDO
                6,070 Mohm on R7602 on GND
                I'm sorry piernov,
                but for PP3V3_S5 and PP5V_S4
                what resistances I need to measure?
                • poldo
                  • Mar 2020
                  • 33
                  • italia
                  Sorry Piernov,
                  but you were referring to the resistance of the rails?
                  To be taken in diode mode and with positive tip on the ground?
                  Let me know if I misunderstood.
                  Thank you
