Asus UX51VZ
  • lordmmx
    K6 Computers
    • Apr 2015
    • 48
    • Slovakia
    Asus UX51VZ
    Hello guys,
    I have encountered a huge problem. I got my hands on Asus Zenbook UX51VZ with UX51VZ motherboard, and after I replaced battery, it shows in OS, looks like it's charging, but actually it does not charge. Laptop does work from it as long as there is at least some charge in battery. At first plug in it showed 100% full charge and LED was green, but after disconnecting charger after about 3 minutes it dropped to 2% and stayed that way without charging.
    I tried replacing battery, got another one. same thing.
    when i measure voltage at battery connector, once I plug it in, i get 0V at PIN3 [green wire, from left]
    any ideas?
  • sicilianul
    • Jul 2014
    • 70
    Re: Asus UX51VZ
    When it's plugged in laptop try measure between black and red wires. Connect charger and see again voltage.
    Also on 2 wires (green and yellow guess) you should have 3.3v (communication with motherboard).
    • lordmmx
      K6 Computers
      • Apr 2015
      • 48
      • Slovakia
      Re: Asus UX51VZ
      okay, after measuring, with battery plugged in and multimeter connected to black and red wire it says 14.6V , with charger connected 14.5V .
      other wires are as follows:
      RED - 14.X
      RED - 14.X
      BLACK - GND
      WHITE - 3.3V - charger plugged in, otherwise 0V
      YELLOW - 3.3V - charger plugged in, otherwise 0V
      GREEN - 0V with charger plugged in (when battery unplugged, it says 2.9V)
      BLACK - GND
      BLACK - GND
      According to boardview, green wire is TS1#_BAT_CON (PIN 6)
      • sicilianul
        • Jul 2014
        • 70
        Re: Asus UX51VZ
        Your battery is good and is communicating ok with laptop. Problems is on board or in windows.
        For this laptop do you have a special program for battery? For example at Lenovo if you don't install energy managment the battery charges only 70%
        • lordmmx
          K6 Computers
          • Apr 2015
          • 48
          • Slovakia
          Re: Asus UX51VZ
          probably on board since it does not charge even when turned off. i don't think there is any special software for battery management, at least i can't find any on asus website.
          • sicilianul
            • Jul 2014
            • 70
            Re: Asus UX51VZ
            Try connect and disconnect battery while laptop is powered on and with charger pluged in. See if it says some level of charging and changes imediately. In windows 10 you can see better.
            Also you can use software "batterymon" to see more details about battery.
            • lordmmx
              K6 Computers
              • Apr 2015
              • 48
              • Slovakia
              Re: Asus UX51VZ
              ok, so...
              i have 2 batteries. one is cheap chinese brand from aliexpres (possibly without protection circuit) and one from local seller (also chinese but much more expensive and with all protections possible i guess).
              anyway, expensive one does not show up in windows at all.
              cheap one does show up but does not charge.
              except, when i quickly unplug and replug charger. then it started to charge and battery is still cold to touch eventough I can measure around 16V on red wire.
              • sicilianul
                • Jul 2014
                • 70
                Re: Asus UX51VZ
                Can you measure directly the li-po elements? It's probably that they droped below 3.7 and the laptop doesn't charge'it below some level.
