820-3330-B No image - No Backlight.
  • xalapamac
    • Aug 2017
    • 36
    • Mexico
    The Macbook turn on, I have CHIME sound, I have a normal fan spin. I have the Lcd attached to the Motherboard...
    I have these readings:
    F9700: 12V
    Q9706:
    PPBUS_S0_LCDBKLT_FUSED=12v
    LCDBKLT_EN_DIV=12 V
    PPBUS_SW_LCDBKLT_PWR = 0v
    DDC Circuit:
    u9000: LCD_BKLT_EN = 0v (I understand that you're only present when
    you recognize the Lcd)
    PP3V3_S5_LCD = 3.3V
    PP3V3_SW_LCD = 0v
    PM_ALL_GPU_PGOOD = 3.33v
    I understand LCD_BKLT_EN It's generated in U9600 (PB7A).
    I have these readings in U9600
    PP3V3_S0_GMUX =3.3 v
    PP1V2_S0_GMUX= 1.2v
    PP1V8_S0_GMUX =1.8v
    PP3V3_S0_GMUX = 3.3 v
    PP3V3_S0_GMUX_LRC_VCCPLL = 3.3v
    EG_PWRSEQ_EN = 3.3 v
    GMUX_DEBUG_RESET_L = 3.3V
    My questions:
    -What are the voltages to be measurable to ensure that the u9600 is alive?
    -am I going well in my busage sequence for the fault?
    -what is your recommendation as an expert?
    Thank you for your time
  • piernov
    • Jan 2016
    • 4438
    • France
    Re: 820-3330-B No image - No Backlight.
    As always you need image before worrying about backlight.
    PP3V3_SW_LCD is a good place to start troubleshooting. Requires a known good LCD to be connected.
    • xalapamac
      • Aug 2017
      • 36
      • Mexico
      I have two screens for that model, both of them work perfectly, and they're probe with another motherboard. PP3V3_SW_LCD = 0V
      Put the microscope lamp behind the screen and I don't have a picture of folder.
      Piernov, What's your recommendation?
      • Conste
        • Oct 2018
        • 235
        Do you have a screen on external monitor?
        • BadraYO
          • Oct 2016
          • 5
          • France
          what is the model of the gpu ?
          • xalapamac
            • Aug 2017
            • 36
            • Mexico
            I'm two LCDS. I have two Macbook of the same model and change the LDCS. Both lcd works with another motherboard.
            GPU: NVIDIA
            S TAIWAN 1222A2
            T0A506 M4P
            N13P-GT-W-A2
            • MobileXT
              • Oct 2012
              • 214
              Try Reflow U9600
              • bdawg
                • Oct 2014
                • 13
                Hey there, I have the same board with the same issue and have a question about U8900. All of the correct voltages and enables are present for the chip but there is no output on pin 1 (pwrgood). I have replaced the chip and still same result. Any suggestions or direction on this matter would be greatly appreciated. Thank you!!
                • piernov
                  • Jan 2016
                  • 4438
                  • France
                  You should list your voltage measurements. Also, always start with history of the machine, symptoms and visual inspection.
                  • maxmark
                    • Aug 2021
                    • ca
                    hey guys! I have the same question too! you replaced U8900 or U8000(GPU)?
                    Did you fix your computer at last? Any suggestions or direction on this matter would be greatly appreciated. Thank you!!
                    • mon2
                      • 14984
                      hi @maxmark.
                      First check that your display is working by using a flashlight on the display to confirm that you can see the graphics. If your display permits, use the flashlight on the back of the display where you can see the Apple logo. If the lid is solid, apply the flashlight around the front side edges. The flashlight will mimic the missing backlight.
                      Do you see the desktop, etc. graphics ?
                      Aside from the missing backlight, this laptop works normally ?
                      Do consider to apply the PRAM reset on your unit as well.
                      https://setapp.com/how-to/reset-pram...and-smc-on-mac
                      • maxmark
                        • Aug 2021
                        • ca
                        Originally posted by mon2
                        hi @maxmark.
                        Thanks for your reply!Yes,I did,but Still doesn't work. no display,but have CHIME sound. VRAM 0V,maybe GPU die
                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:20 PM
                        • Jaime Morillo
                          Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                          by Jaime Morillo
                          Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                          The TV was stuck on the logo and I couldn't access the update menu.
                          I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                          The image result was good, but the image is inverted.
                          The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                          Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                          08-18-2025, 11:38 AM
                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          09-06-2024, 10:56 AM
                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
