Acer Aspire R3-131T no backlight
  • CambridgeMart
    • Feb 2020
    • 11
    • uk
    I'm trying to repair an Acer R3-131T which has display problems. The panhel is working as I can see an image if I hold a bright ligtht up to it, but the backlight is dead. I've checked the signhals on EDP1 and I have +16V on 37-40, +3.2V on eDP_BLEN_CON (pin 34) and +0.5V on eDP_BLCTRL_CON (pin 35).
    I don't know what signal levels should be on 34 and 35, so not sure if I should be fault finding the mainboard or the display.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Acer Aspire R3-131T no backlight
    Check LCDVDD 3.3V
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      Here is the problem, should be 3.3V, so to speak if you short eDP_BLEN_CON with the eDP_BLCTRL_CON the backlight will turn on (but don't do it, just find why eDP_BLCTRL_CON is low).
      Become a Badcaps supporter
      Thanks to all supporters.​
      • CambridgeMart
        • Feb 2020
        • 11
        • uk
        Thanks, that's what I needed to know.
        • CambridgeMart
          • Feb 2020
          • 11
          • uk
          eDP_BLCTRL_CON is low because eDP_BLCTRL_CPU is low, now I am stumped because I can't track the signal back further than R5227 as the next point that the signal surfaces at is below the CPU package.
          Update, I managed to locate the trace at the unoccupied R804 pad, eDP_BLCTRL_CPU is low there as well.
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Check all resistors and fets in eDP_BLCTRL_CON and eDP_BLCTRL_CPU and resistance to ground in lines, disconnect screen cable (remove the battery and charger first) and measure again. Check hall sensor.
            • CambridgeMart
              • Feb 2020
              • 11
              • uk
              LID_CLOSE1# and LID_CLOSE2# read high with the lid open which appears to be correct if I'm reading the datasheet for the Hall sensor correctly.
              eDP_BLCTRL_CPU reads 230k to gnd, so no sign of a problem there (readings taken with the panel disconnected). The FET Q5202 and bipolar Q5203 appear to be functional.
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                Will be a dood idea to uplead datasheet here, so if anyone wants to help to see it.
                Readings with the panel connected (let me remind you once again - remove the battery and charger when connecting or disconcerting screen)? Did you check all resistors in lines for match with the datasheet values?
                • CambridgeMart
                  • Feb 2020
                  • 11
                  • uk
                  All the resistors check out with the values on the schematic. The voltage readings on eDP_BLCTRL_CPU, Q5203 and Q5202 are all exactly the same with the panel connected. I also checked the Hall sensor with a magnet and confirmed the LID signals do change, going low when the magnet is brought near the sensor. It seems the output from the CPU isn't correct.
                  Datasheet for the Hall sensor is attached.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    Come ooon, I meant to upload the whole datasheet, not just the Hall sensor one.
                    Anyway if we're looking the same datasheet eDP_BLCTRL_CON comes from eDP_BLCTRL_CPU_R, and eDP_BLCTRL_CPU_R comes from 3D3V_S0, so check that line and the resistors (RN5257 and R5220) in it.
                    So to speak when the laptop is ON 3.3V shold be present in that line, and the line is:
                    3D3V_S0--->RN5257--->eDP_BLCTRL_CPU_R--->R5220--->eDP_BLCTRL_CON
                    Simple as that.
                    • CambridgeMart
                      • Feb 2020
                      • 11
                      • uk
                      Oh, you mean the schematic, I'll put it up a little later.
                      OK, so eDP_BLCTRL_CPU_R is being held low by Q5202 because pin 5 is high as a result of Q5203 being off; Q5203 is off because eDP_BLCTRL_CPU_Q is low due to eDP_BLCTRL_CPU being low.
                      • CambridgeMart
                        • Feb 2020
                        • 11
                        • uk
                        Acer R3-131T (Wistron Chopper 1-14299-1) schematic.
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Yea, now it's better.
                          You mentioned that you checked all the fets and resistors, give the measurement results.
                          I don't know why we hang around for so long, this is not a complicated case, the fault can be detected quickly, in my opinion the fastest way will be this - unsolder RN5257 and take voltage measurements on pins 5.7 and 8, and everything will become clear.
                          P.S. After that and in case eDP_BLCTRL_CPU is really missing (low) and R5227 is ok, solder back RN5257 and there is nothing to do but to unsolder pin 3 (Q5202), so at least you can have a backlight and be able to use the laptop.
                          • CambridgeMart
                            • Feb 2020
                            • 11
                            • uk
                            My measurements around Q5202 and Q5203:
                            Q5202 G2 (5) 3.3V, S2 (4) 0.0V, D2 (3) 0.0V
                            Q5203 B 0.0V, C 3.3V, E 0.0V
                            With R5257 removed, its pads measure:
                            5 0.0V, 7 3.3V, 8 3.3V
                            So eDP_BLCTRL_CPU is really missing (low) and R5257 is OK, so I'm no further forward! Resistance readings on eDP_BLCTRL_CPU indicate that the trace is connected to the CPU, so I suspect something else is amiss; I'm now contemplating setting eDP_BLCTRL_CPU permanently high as you suggest.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              ... 5 0.0V...
                              Yea, quite a bad news unfortunately.
                              ...and R5227 is ok..
                              ...and R5257 is OK...
                              R5227 - how much is the measured value in Ohms? Also measure voltage drop (diod mode) both sides to ground.
                              I do not see another solution (but first tell me the R5227 measurements values), at least you will be able to use the machine.
                              • janifaisal538
                                • May 2017
                                • Pakistan
                                I need bios of this mode.. can anyone plz give me org dump of this model?
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  Create your own topic at "BIOS Requests ONLY!" section, but use forum search first:
                                  https://www.badcaps.net/forum/showth...hlight=R3-131T
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    Wait a minute LID_CLOSE1# and LID_CLOSE2# - both signals must be active low and you said "read high with the lid open". That's it! Bring back both signals low at the Hall sensor and check eDP_BLCTRL_CPU line voltage (pin 5 at RN5257). I believe it will go high and Hall sensor as I suspected is the problem here.
                                    P.S. But still take the R5227 measurements values.
                                      ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 02:30 PM
                                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-06-2024, 05:27 AM
                                      ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
