MacBook Pro 2011 820-2936-B won't start
  • bmwpowere36m3
    • Jan 2020
    • 6
    • US
    Found Wife's 13" MBP one night with the case swollen, opened screen and trackpad bulged out. Immediately thought battery had died and swelled. Sure enough that was the case. However after removing battery and plugging in, it worked fine. Ordered a new battery, put it in and it seemed to be working fine and charging. Few days go by....
    Now the laptop won't start, no battery indicator, nor green light on magsafe. Searched around, found some info on "one-wire circuit" and started checking the logic board.
    I don't see any damage, maybe a few spots that have a reddish/brown discolored on some of the gold pads. Maybe light corrosion from possible gas leaked from damaged battery.
    Logic board is a 820-2936B and I'm getting no power on: PPBUS_G3H or PP3V42_G3H. I'll double check U6990, but I had voltages of 16.5 input, 14.5 input with resistor and 3.8 V on FB IIRC.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: MacBook Pro 2011 820-2936-B won't start
    Take board out of the chassis, disconnect everything from the logic board except DC-in board and fan and plug in Magsafe. See if that makes any difference.
    If not, measure resistance to ground on PP3V42_G3H.
    • bmwpowere36m3
      • Jan 2020
      • 6
      • US
      Those observations were with just the logic board, ram, fan, DC board and plugged into charger.
      PP3V42_G3H is 0 ohms to ground
      • piernov
        • Jan 2016
        • 4435
        • France
        0 ohm to grounds means it's fully shorted to ground. There's a dead component somewhere on the line. Inspect visually the board especially around the spots where PP3V42_G3H goes, and if you can't spot anything, inject 1V with a lab PSU and find the component that's heating up.
        • bmwpowere36m3
          • Jan 2020
          • 6
          • US
          I'll have to figure out how to supply 1V, besides purchasing a lab PSU. Are we limiting the inject to certain amperage?
          Seems freeze spray or canned air can help identify the heated component.
          • bmwpowere36m3
            • Jan 2020
            • 6
            • US
            Got a power supply to test with and applied 1.2 V which drew 2A on PP3V42_G3H and C6999 is vaporizing denatured alcohol of board.
            • piernov
              • Jan 2016
              • 4435
              • France
              Yep so you found the culprit. C6999 has to be replaced. (not just removed, it is a critical cap since it filters and stabilizes the output of PP3V42_G3H regulator)
              • bmwpowere36m3
                • Jan 2020
                • 6
                • US
                Replaced C6999 cap, PP3V42_G3H is 3.47 VDC, green light comes on, fan spins. Assuming good to start putting together?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Sounds good yes.
                  • korben_dallas
                    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                    by korben_dallas
                    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                    MY QUESTION:
                    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                    02-14-2024, 12:23 AM
                  • ledbylight
                    M1 A2337 Macbook - No Display, likely due to logic board
                    by ledbylight
                    Hi all!
                    This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                    I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                    11-04-2024, 06:36 PM
                  • _Cupa
                    MacBook Air 2011 13" >820-3023 A< no power (PLT_RESET_L missing)
                    by _Cupa
                    Dear community,
                    this is my very first post, I am quite new to macbook repairs, and I am excited:-)
                    I have a 2011 MacBook Air 13' that does not power on. No fan spin, nothing.
                    Here are the specs:
                    MacBook Air Mid-2011
                    CPU: 1.7 GHz Core i5 (I5-2557M)
                    Model: A1369 (EMC 2469)
                    RAM: 4 GB
                    VRAM: 384 MB
                    The first question:
                    Unfortunately, it came with a 'fake' power adapter which seems not to talk to the computer. Sometimes it does show green light immediately after connecting it to the board,...
                    04-01-2021, 02:01 PM
                  • yuuki47
                    A2681 M2 MacBook Air Dead Logic Board
                    by yuuki47
                    Hello...
                    My sister purchased an M2 MacBook Air a year and a half ago. While she was using it a week ago, it randomly shut off and no longer powers on. There are no signs of life and not even the MagSafe indicator LED lights up.
                    We took it to Apple and they disconnected the battery and tried a bunch of stuff before they declared the logic board "brain dead" and quoted us about £567 to replace it. Typical of them...
                    eBay replacements run about £367 with the Touch ID sensor included.
                    I did consider to probe the logic board for shorts...
                    04-13-2024, 06:22 AM
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
