Clevo W670SJ /W650SJ - PowerOn light is on but nothing works
  • WinUser
    • Sep 2019
    • 13
    Hello all and greetings from germany ,
    I have a strange notebook here, a clevo W670SJQ1, motherboard is a W650SJ. Problem is: When press the PowerButton, the PowerOn light goes green (on) but nothing happens - no Fan spinning, no HardDisk Spinning. Notebook stay in this status until i press the PowerButton again for ~4 sec to power down.
    Battery Charging works fine (LED goes orange, when its full it goes to green).
    I have many experience in notebook and graphic-card repairs (many years)
    but the thing here is a mystery to me . I have many equipment like hotair station, thermal camera, experience in bga reballing (with leaded solder balls and stencils)
    So, i checked on the dismounted motherboard:
    - all coils for short - nothing, all coils not shortet to ground
    - 19V is present on all PowerRail Mosfets
    - @19V when the notebook is complet off it draw round 2mA. when powerbutton is presed and notebook is in On state it draw only 36mA@19V...
    - in this PowerOn State - nothing gets unusually warm, only Super IO Chip and PCH will heat up about 3-6 ° C warmer than the environment (thermalcamera view)
    - no 5V, CPU or GPU powerrails goes on
    Weired things:
    - in off state - on the PowerButton there is 18.5V (i know only 3.3V on other notebooks). This voltage will short to ground when press the powerbutton and the powerOn LED will light on (green). when the system is on, there is only 17V on the powerbutton
    - when powered on - the only "rail" that will switch on is the PCH, it becomes round 1.3V, but i think its not the VCC for the PCH (then the PCH must getting hotter i think)
    - bevor this here happens - the system was often reset in the bootup-process (windows-start) like short power-off automaticly power on and start windows...or it will stuck in this "boot-loop" until i manual power off the system and power on again, then it have run fine...but no - nothing mor happens
    so, what can be the problem here? any tips for me?
  • WinUser
    • Sep 2019
    • 13
    Re: Clevo W670SJ /W650SJ - PowerOn light is on but nothing works
    *edit* i figured out that the 3.3V Powerrail is always on, and the 5V rail goes on (also on USB, but not on ODD/HDD) when powering on the notebook.
    1.3V also present on RAM, but ram dont get warm (also testet with another ram)
    • WinUser
      • Sep 2019
      • 13
      ServiceManual here
      I do not know how the startup process works, what elements becomes a poweron signal...what to measure now...the other repaired notebooks hase only simple errors like capacitor short, or blown mosfet, but this notebook here is a harder case.
      • piernov
        • Jan 2016
        • 4435
        • France
        Either measure all power rails, or at least check some checkpoints in the power sequence as I'm not sure what state the board is in.
        Measure voltage just after triggering power button.
        RSMRST#
        SUSC#
        SUSB#
        ALL_SYS_PWRGD
        SYS_PWROK
        • WinUser
          • Sep 2019
          • 13
          hello piernov, thanks for help
          question: can i measure the voltage diretly on ITE SuperIO? when i look at the schematics, some voltage will go in, and some go out...but when a voltage is "generate" by PCH - how can i measure it? its a BGA chip. Test points not shown in schematics
          • piernov
            • Jan 2016
            • 4435
            • France
            Measure on any components as long as it's the same line. Use the easiest to find and to put the probes on.
            • WinUser
              • Sep 2019
              • 13
              ok, here the measurements:
              RSMRST# 3.25V directly on ITE SuperIO
              SUSC# 3.25V directly on ITE SuperIO
              SUSB# 3.25V directly on ITE SuperIO
              ALL_SYS_PWRGD 0V directly on ITE SuperIO
              SYS_PWROK 0V
              PWR_SW 3.25V directly on ITE SuperIO
              1.05V_LAN_PWRGD 3.3V
              DDR1.5V_PWRGD 3.3V
              1.05VM_PWRGD 3.3V
              PM_MPWROK 3.3V
              V1.05M_POERGO_AND 3.3V
              PCH1.5VS_PWRGD 0V
              DELAY_PWRGD 0V
              PM_PCH_PWROK 0.9V
              PCH_PWROK 0V
              G5310 (1.5VS, servicemanual page 97 )
              EN_SKIP 0V
              so, the PCH1.5VS_PWRGD signal is fail, in the schematics, the mosfet PQ19 on page 97 also, is blocking the enable signal for the G5310 buck Converter (1.5V PCH). PQ19 Gate have 3.3V on it...so now, i must see why.
              weired thing...the PWR_SW out from the ITE SIO deliver 3.3V...but on the poweron button i have 19V...i havnt look why, i think ther is near the poweron switch a transistor...but - i dont know why this...
              but now - i must looking why PCH buck-converter is not powering on... anny suggestions?
              • piernov
                • Jan 2016
                • 4435
                • France
                So it's getting into an S0 but ALL_SYS_PWRGD is missing due to an issue on an S0 rail. PCH1.5VS_PWRGD indeed is missing.
                SUSB is supposed to be low as SUSB# is high. See PQ23B circuit.
                Some platforms will have B+ on the power button, dunno on this one, maybe ok.
                • WinUser
                  • Sep 2019
                  • 13
                  GOT IT
                  notebook repaired...
                  N Channel Dual Mosfet MTDN7002ZHS6R (Location PQ23) was broken...its a "inverter" for DD_ON# and SUSB...but on SUSB the Drain stays high although the gate was also high...
                  swapet with a other one in stock - a 2N7002KDW - and now it boot up like a charm
                  The broken MTDN7002ZHS6R was "half broken" - never seen...when gate high, the 3.3V over 10k on Drain was only droped down to round 2.7V...not enough.
                  So, notebook works.
                  thanks for help
                  • qonma
                    Kuli Solder
                    • Jun 2017
                    • 184
                    • INDONESIA
                    good post
                    • AmuroRay
                      • Jun 2021
                      • 3
                      • Malaysia
                      I have the same problem with this laptop. Is it normal if the switch on pin 1 voltage is 19v? I have changed the mosfet in pq23 because it was faulty and the laptop bootup fine, but there is another problem, the laptop will shut down and start on repeatedly until i turn it off.
                      • AmuroRay
                        • Jun 2021
                        • 3
                        • Malaysia
                        I think i fix it, it was bad bios. I reflashed the bios using tl866ii plus programmer and also flash ec firmware, the laptop now working good again. Thank you..
                        • Mdink
                          schematic for clevo w650sj and board number 6-77-w650sj00-d01
                          by Mdink
                          Hi, please I need schematic for clevo w650sj and board number 6-77-w650sj00-d01. I would be grateful for your help.
                          07-06-2025, 05:11 PM
                        • Günter Schuch
                          searching for Schematics & Boardview for Clevo P641HK1
                          by Günter Schuch
                          hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                          Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                          05-14-2025, 06:34 AM
                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                          10-04-2024, 03:59 AM
                        • TecnicaNTT
                          Convert Clevo PC70DD to UMA
                          by TecnicaNTT
                          Can somone please help me unlock or convert this Clevo PC70DD2 BIOS to UMA only?
                          The motherboard just burned a hole in the GPU VRAM VRM circuit and now there is a 19 Volt short spread across the GPU and VRAM side. I isoalted both circuits from the rest and now I can get the laptop to work and display image with integrated Intel graphics but crazy fan spin and shutdown after some minutes because of missing dedicated Nvidia GPU.
                          Laptop: Clevo
                          Model: PC70DD2
                          Serial Number: NPKC70DD2000E0017S
                          Motherboard P/N: 6-77-PC70DD2-N02C-1D
                          Motherboard S/N: NKPC70D...
                          11-12-2024, 05:14 AM
                        • monitron
                          Bios Clevo NL51RU
                          by monitron
                          I am struggling with a Clevo NL51RU linux laptop that does not boot because of a corrupt main bios.
                          I did not succeed to build a new bios. Maybe somebody has more experience with this laptop and can build a working bios for me or has a working dump.
                          Clevo NL51RU
                          ser: NKNL51RU0001D00318
                          Many thanks!...
                          05-27-2024, 11:02 AM
