Imac A1311 Lcd problem
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hello, I have an imac with problems with the display, it shows the normal screen but there are irregular lines. I connected it to an external monitor and the image is perfect.
    I thought the problem was the LCD and so I bought a used panel disassembled from another Imac, always A1311, which surely has problems on the plate. But surprise the purchased LCD is always a LG LM215WF3 but mine is (SL) (A1) while the purchased one is (SD) (A1). Do you think they are compatible? the most important difference is the different connection cable (4 wires) which in my flat is while the other has the wires and connector.
    If I make a change by welding the wires on the board?! it works ?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Imac A1311 Lcd problem
    One is 2009 and the other is 2010. Not sure if they are compatible. Knowing Apple, probably not.
      • 21853
      The voltage is different, one is 5V the other 12,and other differences too,see the datasheets.
      • Fabbrone
        • Jun 2015
        • 158
        • italy
