Lenovo Ideapad 305-15ibd died and won’t turn on.
  • Arabianwinter
    • May 2019
    • 7
    • England
    So I’ve had this laptop for a couple of years and it had been looking worse for wear recently. Anyway, it finally just stopped working yesterday mid session. It doesn’t power on and there are no lights at all, and the fan doesn’t spin up.
    I have taken a look inside and realised I have no idea what I’m doing as I’m a beginner. I’ve tested the DC jack... works fine. Charger delivers 20.6V and that comes through to the jack. I found the schematics for it on this forum but in honesty I don’t know what I’m looking at. I understand the basics but not exactly how the schematics are supposed to help me. Anyway, I tested JDCIN1. The first and second rails jump between 0.8V and 1.8V and the rest are 0V. From what I’ve seen of similar models the first and second rails should be 20.6V like the charger and DC jack?
    Anyway, this is as far as I have gotten. Any help would be appreciated or any sources on how to diagnose problems with the circuit using the schematic diagrams as I would like to learn. Thank you.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Lenovo Ideapad 305-15ibd died and won't turn on.
    Try disconnecting the AC adapter & battery. Press and hold the power button for 30 seconds. Reconnect power and try starting the Mob again.
    Try another AC adapter or try that adapter on another Lenovo
    If none of that helps
    Test Pl101 Pl102 for +20V
    ADP_ID 3.3V ,AC Adepeter 90W?
    RTC Battery 3.3V
    PQ301 fet pin 5.6.7.8 +20V pin4 8.8V pin 1.2.3 +20V
    Voltage on PQ302 must be the same measurements
    • Arabianwinter
      • May 2019
      • 7
      • England
      I don’t currently have another adapter to test but it produced the right voltage with a multimeter (around 20V). The centre pin produces a .286 ohm
      My adapter is rated for 65W.
      I will see if I can get another one to test as it is getting very hot at the tip.
      No change removing battery.
      PL101 and PL102 both 0.8-1.8V
      PQ301 all pins produce between 0.8-1.8. These are all the same as pin 1 and 2 JDCIN1 I’m not sure exactly but could the fault be with the JDCIN1 connector? .
      Battery 3V.
      Thanks for your response.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Most probably main line 19V short to GND that’s why tip of the adepter getting hot,now it’s time to do cool checking with out power & Battry, test your first 2 P-Channel PQ301/302 Mosfets for Readings, check out YouTube /Google how to test P-Channel fets
        • Arabianwinter
          • May 2019
          • 7
          • England
          Okay thank you I will try that!
          • Arabianwinter
            • May 2019
            • 7
            • England
            I've tested pq301 and pq302... pq302 drain to source on the continuity test beeps which according to tutorial means it's damaged?
            Also diode mode produces measurement of 0 resistance which indicates it is defective but I'm not sure.. Pq301 reads just a 1 for all pins on diode mode and no beep on continuity so I'm guessing that one is fine.
            Is this the fault here on pq302? Or could the mosfet just be on/off and I don't know it?
            • Techtiger
              • Oct 2014
              • 1601
              • france
              Put the black probe in Source Red Probe in Drain diode or Continuity mode the Good Value some ware around .500
              Put the black Probe in Gate Red Probe in Source Good Value 0 or high, upload the Values of both Fets
              Most of the time 1st Mosfet PQ301 RBFET protect the Mob from EMI (electromagnetic interference) killing it self
              • Arabianwinter
                • May 2019
                • 7
                • England
                PQ301 - diode mode
                Pins 8, 1 - .972 ohm
                7, 2 - .664 ohm
                6, e - .662 ohm
                Gate -> source .262 ohm
                PQ302 diode mode
                8, 1 - 0
                7, 2 - 0
                6, 3 - 0
                Gate, source - .262ohm
                • Techtiger
                  • Oct 2014
                  • 1601
                  • france
                  Originally posted by Arabianwinter
                  PQ301 - diode mode
                  7, 2 - .664 ohm
                  6, e - .662 ohm
                  PQ302 diode mode
                  8, 1 - 0
                  7, 2 - 0
                  6, 3 - 0
                  remove PQ302 with the help of a hotair station hope you have it, test the Fet out of the Mob , do you have a replacement P-Channel Fet 30V ?
                  • Arabianwinter
                    • May 2019
                    • 7
                    • England
                    Thank you for your help so far!
                    I will get my hands on a hot air station and fet and try that. Am I looking for the resistance to be 0 like when it isn’t on the board?
                      Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 05:20 AM
                      Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                      Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad 3 14ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 14ITL6 boardview and IdeaPad 3 14ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-07-2024, 05:00 AM
                      Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
