Asus x550l display problem
  • thinkfast76
    • Mar 2017
    • 46
    • italia
    I have a strange problem with an asus x550l.
    show on external screen but no signal on its led.
    I would like to test the LED fuse. can anyone tell me what it is?
    i have the border view
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus x550l display problem
    check J4501 LDVS connector
    pin 29 30 31 for 19V AC BAT SYS INV CON
    pin 27 for 3.3V BL EN
    pin 5 & 11 +3VS
    report back
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      I notice that part for supply LVDS seem all connected directly:
      • JP4503 for 19V (jumper pad)
      • SL4504 for PANEL_VCC (seem coil)
      • SL4501 for +3VS (seem coil)
      Maybe related problem on U4501
      Refer the boardview with x552 schematic, quiet close i think. Just click x552
      • thinkfast76
        • Mar 2017
        • 46
        • italia
        Thx a lot guys, i will report tomorrow
        • thinkfast76
          • Mar 2017
          • 46
          • italia
          So i check....
          JP4503 for 19V (jumper pad) 1,89v
          SL4504 for PANEL_VCC 18v
          SL4501 for +3VS 3,21
          But i I saw that jumpering pin 11 and pin 12 of j4501 the monitor produces an image but without backlighting
          • on/off
            • Oct 2016
            • 333
            • Indonesia
            Originally posted by thinkfast76
            So i check....
            Seem not correct???
            why 19V be 1.89V
            panel vcc come from +3V_EDP be 18V?? double check your measurement
            • thinkfast76
              • Mar 2017
              • 46
              • italia
              Originally posted by on/off
              Seem not correct???
              why 19V be 1.89V
              ok,l will check again,sorry for this.
              Can you tell me why if you jumper pin 11 and 12 the image appears but without backlight?
              Thx a lot for your time
              • thinkfast76
                • Mar 2017
                • 46
                • italia
                Then measuring the voltages, on j4501, everything seems ok except on pin 10 and pin 27. On pin 10 measure 2.14v on pin 27 0V. Checking in the circuit I saw that the only component in common between these 2 pins and R4530, also measured this on pin 1 always 2.14V.
                I think the problem is U4501 that at pin 5 always measures the damn 2.14 not enough to power the screen. In fact, bridging on j4501 pin 10 and pin 11 (which from 3.14V) the panel turns on but without backlighting. So I think the pin 27 feed the backlight and pin 10 the screen. Tips?
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  Test U4501 pin 20 for 3.3V PANEL VCC 3.3V if you have 3.3V on that pin test all the components related for that SL4504 SL4522 C4512 C4517,
                  R4530 is your BL EN & PANEL VCC
                  Test U4501 pin 44 for 3.3V BL EN test all the components related for that
                  • thinkfast76
                    • Mar 2017
                    • 46
                    • italia
                    I will try thx a lot
                    • hezareh2000
                      • Jan 2019
                      • 32
                      • Iran
                      hi, request bios asus a550ldv rev 2.0
                      thank you
