Toshiba S55T shorted
  • Conste
    • Oct 2018
    • 235
    Hey there,
    I have a new problem. Toshiba S55T - Board Petatron VGS Rev. 2.1.
    Board doesn‘t get power, power jack is okay. I think because of a short the Board is shutting down.
    Tried to give it a lower voltage than 19v with a laboratory power supply I have bought, but no power draw at all. Bridging the first Mosfets results in 0,2A power draw at 19v and an IC, I guess 3/5v regulator gets hot?
    Could the KBC be the problem? It is an ITE 8587E.
    Does anyone have a boardview?
    Thanks in advance,
    Constantin
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Toshiba S55T shorted
    Need the Schmatic to help check for LDO5 & LDO3 is Generating from the regulator
    • Conste
      • Oct 2018
      • 235
      The IC which is getting hot is a TI 1225c, shall I desolder it?
      Or is the problem a capacitor?
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        Lots of Repair... Friend
        Possible may be a Capacitor. but you need to Check the following.
        but you need a Schema diagram.
        Start on 19v rail... you can used LED light indicator that indicating totally Shorted
        check have 19v. check fuse then coil on Main Mosfet then check the Mosfet...
        must better used your Sense of Sight may some parts have Burn.
        hoping can help you for little Part...
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          Try this.
          but you need an ASC opener program.
          if you have can i Copy.
          Here the Schema
          • Conste
            • Oct 2018
            • 235
            Originally posted by lorins_core
            Try this.
            Here the Schema
            Wow! thank you Opened it with boardviewer, works fine.
            How shall I start?
            I also saw a Little spark when connecting the laboratory power supply to the unit, I guess the board is pulling amps and shuts down then because of short.
            The unit which is getting hot is U8100, but I think this isn't for EC powering, but for further steps or am I wrong?
            Fuses are good, no burned parts sofar. But Q8802 was changed before, I saw on soldering Job.
            • Techtiger
              • Oct 2014
              • 1601
              • france
              test U8100 pin 3.12.13 6.20 for voltage
              • Conste
                • Oct 2018
                • 235
                Pin 3: 12,7 mV - nothing
                Pin 12: 0,819V
                Pin 13: nothing
                pin 6: nothing
                Pin 20: nothing
                After Q8800 I only have those 0,819V like on PIN12.
                • Conste
                  • Oct 2018
                  • 235
                  +3VA_DX has only 13 ohms - guess thats the reason of short.
                  I removed various parts - JP8108 / JP8101
                  Fuse after second Mosfet
                  CE8101 and U8100
                  Short on+3VA_DX not present anymore, Short on +RTC_Power also. I think TI 1225 (U8100) was the bad one.
                  Will bridge the fuse tomorrow solder a new EC inside.
                  After that, I will try to find a TI 1225 from a donor board maybe
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    remove the cap C8101 and test pin3 U8100 short to GND if not trace it back
                    pin 12 shoul be +19V to turn on LDO3 LDO5 on U8100
                    • Conste
                      • Oct 2018
                      • 235
                      Cap 8101 and U8100 are removed, but I still don‘t have 19v on Pin 12
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        Voltage in Q8802 all pins Q8800 all pins ? 123 4 5678 ?
                        • Conste
                          • Oct 2018
                          • 235
                          Q8800
                          Pin 1,2,3: 0,934V (drain)
                          Pin 4: 0,935V (gate)
                          Pin 5,6,7,8: 18,83V (source)
                          Is Pin4 too low or is something defective?
                          Q8802
                          Pin 1,2,3: 0,934V
                          Pin 4: 0,934V
                          Pin 5,6,7,8: 0,934V
                          • Techtiger
                            • Oct 2014
                            • 1601
                            • france
                            test the 2 Mosfets in Diod mode multimeter for short cannot tell exact N or P Channel
                            black Probe in S Red Prob in D Pchannel Value / Red Probe in S Black Probe in D Ncannel Value. (Is Pin4 too low or is something defective?)yes YOU dont'n have the gate pass in 1st Mosfet you have a resester and a Cap connect with the line tet them too
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              if it's P Channel +3V in Gate if it's N +22V in Gate Pass
                              • Conste
                                • Oct 2018
                                • 235
                                Both MOSFETs show 0,14V in both direction. Also desoldered some more parts, but I don't get any process.
                                Guess I'll order one from china for 50 Euros
                                • Techtiger
                                  • Oct 2014
                                  • 1601
                                  • france
                                  if not put a jumper remove Q8800 5678 (19V) connect pin 123 (19V) do you have a power bench first give 1V to see if it's passing
                                  https://www.youtube.com/watch?v=yLffdWhBfFU
                                  dont'n give up now
                                  • Conste
                                    • Oct 2018
                                    • 235
                                    Sometimes I had a short on 19V line and sometimes not, coil for 3,3V was getting hot then.
                                    I then removed a Jumper and +3V_SYS was on short so I also removed many components...in the end I got a short everywhere…
                                    Don't want to waste too much time on this one, since it has been soldered on it before me, so I will get a new one, it's better.
                                    There are many more Motherboard to repair here
                                      09-06-2024, 05:27 AM
                                      09-06-2024, 05:59 AM
                                      Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                      This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                      09-06-2024, 05:33 AM
