ASUS H81M-C usb ports and lan port not working
  • ScorpioMan86
    • Dec 2016
    • 94
    • South Africa
    Hi Guys,
    I got an ASUS H81M-C that has an issue, none of the usb ports or lan port work. link to the mobo https://www.asus.com/za/Motherboards/H81MC/
    I can however use a pci to usb card with no issues, there's also no lights on the lan port when plugging in a lan cable.
    Any idea on how i can possibly fix this ?
  • cacla
    • Apr 2015
    • 442
    Re: ASUS H81M-C usb ports and lan port not working
    You try to flash it ?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      I suspect its PCh as both lan and usb are controlled by pch but cant say with certainity without checking. Remove the lan chip and see if it makes any difference. Next check all usb circuit. I dont think its to be a bios issue.
      • piernov
        • Jan 2016
        • 4437
        • France
        Could be 2 separate issue. Check in the OS if the USB controller/hubs are detected, and check if the Ethernet controller is detected.
        If they are both detected then for the USB check with front panel headers and check if you have 5V. For the Ethernet check if the Ethernet lines are shorted to ground (either dead Ethernet controller or shorted ESD diodes or shorted filter caps). If not, replace the Ethernet controller first, then the Ethernet port (should have integrated transformer that may be bad).
        If the Ethernet controller is not recognized inside the OS, then check its supply voltage, if it's present replace Ethernet controller.
        For the USB stuff if 5V is present and none of the ports work (back panel and front panel headers) then most likely PCH issue.
        I'd try to flash BIOS as suggested by @cacla, you never know even though it's highly unlikely.
        • ScorpioMan86
          • Dec 2016
          • 94
          • South Africa
          Hi there,
          I have flashed it and replaced bios chip with a well working one but no changes
          • ScorpioMan86
            • Dec 2016
            • 94
            • South Africa
            Thank you , will be doing removing the lan chip and will provide feedback
              ASUS 3F-AP201C-A, Specification for Upgrade or Repair
              This specification for the ASUS 3F-AP201C-A, can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3F-AP201C-A, boardview and 3F-AP201C-A, schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS 3F-AP201C-A,...
              09-06-2024, 05:27 AM
            • Fluxi_77
              HP 355 G2 Left USB Ports and Ethernet Port not working
              by Fluxi_77
              Hello Guys,
              I currently have a problem with an HP 355 G2 where the right USB Port works without a Problem but the left ones and the Ethernet port which is also in the region of the two USB ports are not working.
              The HP Hardware Diagnostic tool also shows them as faulty. I used a USB tester and it also shows that I don't have 5V on the ports so I suspect a problem with an IC that controls the Voltages that goes to this ports.
              Unfortunately I found no boardview or schematic for this device and I am a newbie in tech repairs so I don't know where to start. Other than this problem...
              02-19-2025, 12:29 PM
              ASUS VivoBook N580GD-DM230T Notebook Pro Specification for Upgrade or Repair
              This specification for the ASUS VivoBook N580GD-DM230T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N580GD-DM230T boardview and N580GD-DM230T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 07:02 AM
              ASUS VivoBook N580GD-XB76T Notebook Pro Specification for Upgrade or Repair
              This specification for the ASUS VivoBook N580GD-XB76T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the N580GD-XB76T boardview and N580GD-XB76T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              ASUS VivoBook X541NA-GQ638 Notebook Max Specification for Upgrade or Repair
              This specification for the ASUS VivoBook X541NA-GQ638 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X541NA-GQ638 boardview and X541NA-GQ638 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 06:45 AM
