Re: HP EliteBook 840 G2 power problem
My suggestion is that either you source the proper tools to remove this mosfet or consider to take to a local cellphone or computer shop that can do the same. You need a good hot air tool with flux. Underside pre-heater will also help for heating up multilayer pcbs. Ask around if someone local to you services at the component level.
Cellphone repair shops will have the tools and experience to do this without losing the surrounding parts. You will need to find the replacement mosfet. This can be the same one or an equivalent. Same one can be found on AliExpress. If required, can search for a replacement.
It's indeed a shorted mosfet (Q6051) after testing the resistance between gate & drain there was only a few ohms (not dead short, but shorted enough that the source was only 4v instead of 12v)
It was very hard to unsolder, it's entirely soldered underneath and there is a very small 10k resistor just next to itLeave a comment:
Remove all power. Meter in resistance mode.
Measure the resistance across the mosfet:
Source & drain
Source & gate
Gate & drain
Post each measurement and the meter scale used for the measurements.
Check q6051 and q6050 for starters. If the readings are low, the mosfet is shorted and must be replaced.Leave a comment:
Sorry for hijacking but I have a problem in the same circuitry, for me the laptop turns on with the adapter and shows battery charging etc but when disconnected it shuts off and doesn't turn on just on battery. The battery is good with 12v voltage but probing PBPACK is at 4v everywhere after Q6051 which I'm guessing is the issue
For some context there was a shorted cap (C6010) which I removed (didn't replace yet as I don't have 10uf 25v on hand) but which shouldn't be a problem if it's not present
This short likely created another failure somewhere since now the battery is not supplying power which is what I'm trying to track down and I could use some pointers
I'm really not familiar with switching supplyLeave a comment:
Thanks Thanks Thanks. l have got also same problem and solved thanks to you. All voltage was okay every thing was okay but it wasnt work. When l changed socket its okay now.SOLVED! The problem was the DC Jack, or rather a poor connection to the center pin. After I read about someone who had the same problem and solved it by crimping the DC jack I measured and found that it did not connect that well. I took a pair of pliers and crimped the base of the DC jack, after that it worked like new!Leave a comment:
Do you remember the voltages on pin 1, 2 and 3 of the power jack?
I'm having some issues, and i think is also the powerjack.
but I read around 19V on pins 1 and 3.
and have a reading of 1.2V on pin 2, but this one seems to have bad contact.
I hope you can answer,
thanksLeave a comment:
I mean that I used a pair of pliers to make the dc jack connector on the motherboard tighter, and that way improve the connection.Leave a comment:
@bollin
What do you mean with crimping base of the dc jack?
Regards
SteveLeave a comment:
Good jobSOLVED! The problem was the DC Jack, or rather a poor connection to the center pin. After I read about someone who had the same problem and solved it by crimping the DC jack I measured and found that it did not connect that well. I took a pair of pliers and crimped the base of the DC jack, after that it worked like new!Leave a comment:
New info: Limit_signal is at 0.16v, should be at 2.7 volts... that's why it doesn't recognize any chargers...Leave a comment:
New turn: after a reinstall of windows due to a unrelated problem, some HP software is now telling me that the smart adapter is not working and that I should replace it. It does however work on my wifes 840 g2, and I get the same message when using her charger on my computer. Back to square 1...Leave a comment:
Shouldn't acdrv be cmsrc + 6 volts for q6011 to open? But cmsrc is only 0.11 volts with battery and charger connected, but 19.5 volts without battery. I will recheck values tonigjt.Here are the voltages on u6000
U6000 with only AC Adapter:
Pin1: 19.4- 17v
2: 19.4- 17v
3: 19.4-17v
4: 25.3-22.4v
5: 0v - 1.35v
6: 2.5v
7: 0v
8: 3.2-3.3v
9: 3.2v
10: 3.2v
11: 0v
12: 2v-1.3v
13: 2v-1.35v
14: 0v
15: 0v
16: 5.92v-5.85v
17: 5.76v-5.7v
18: 2v-1.35v
19: 2v-1.35v
20: 19.4v-17v
Battery connector:
1: 1.6v-1.1v
2: -"-
3: 3.3v
4: 3.3v
5: 0v
6: 3.27v-3.25v
7: 0v
8: 0v
U6000 with AC Adapter and battery connected:
1: 11.69v
2: 11.69v
3: 0.11v
4: 0.03v
5: 3.28v
6: 2.63v
7: 0v
8: 3.29v
9: 3.29v
10: 3.27v
11: 0.01v
12: 11.69v
13: 11.69v
14: 0v
15: 0v
16: 5.92v
17: 11.42v
18: 11.68v
19: 11.68v
20: 11.68v
Battery connector:
1: 11.68v
2: 11.68v
3: 3.3v
4: 3.3v
5: 0v
6: 0v
7: 0v
8: 0v
I would like to add that in the first measures the voltages were most of the time like the first reading but once every se ond jumped to The second reading, hence the varying readings. There were also a a faint ticking sound about once every second, and that went away with the battery present.Leave a comment:
HIDRV is 11.4 volts with both battery only and battery + ac. On ac only it is at 1.5 volt rising to 2 volts at the same rate as the ticking.Leave a comment:
It was, yes. PVBATis 11.4 volts with battery only, 19.4 volts on ac but dropping to 17 volts at the same rate the ticking is heard. PVPACK is 11.4 volts battery only and 1.5 volts on ac only and rising to 2 volts at the same rate the ticking is heard. Q6000 and q6001 are confirmed good, and tgat makes me believe it is a faulty u6000Leave a comment:
The charger is recognized by the bios but not windows ?Leave a comment:
There was an official update, so I tested it. The charger was recognized by the bios update program, it would not work otherwise. Now nothing happens. I will measure resistance as soon as I get home from work.Leave a comment:
			This specification for the HP EliteBook x360 1030 G3 + USB-C Essential Power Bank Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G3 + USB-C Essential Power Bank boardview and 1030 G3 + USB-C Essential Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-06-2024, 11:05 AM
			This specification for the HP EliteBook 1040 G4 + USB-C Notebook Power Bank Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + USB-C Notebook Power Bank boardview and 1040 G4 + USB-C Notebook Power Bank schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 06:27 AM
 - Loading...
