Can anyone teach me about bin file how to remove password with hexaeditor tool
			by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
							Channel: BIOS Requests ONLY!
			by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
			by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
			by justice171Hi BadCaps team,
I’m asking for a bit of community help with a Proline notebook that’s stuck with a Power-ON (BIOS) password. The laptop has very limited info available and I suspect it may be a local (South African) Proline board. Thought I’d check here in case anyone has seen this one before.
What I have:- Model: Proline NoteBook V146GNK
 - Board: SU_GN100_MB_V12_20231120A
 - Serial: GN10Q12124205W1588
 - Notes: 12V main board. Very little documentation available.
What I’d like to request:- Has anyone dealt with this Proline board before or seen matching BIOS/firmware
			by fx1982Hi everyone, can someone please help to remove bios Administrator password or decode as I failed miserably... Tried reading the password but it says wrong password. Thank you in advance!
It's a 2024 Asus Zephyrus G16
GU605MV
SN: S2NRCX035924088
CN: AEDW
MFD: 2024-02 36M
BIOS VERSION: 315...-
 - Loading...
