HP Pavilion DM4 6050A2402401 Motherboard no CPU Vcore
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I'm trying to fire up this laptop which I thought was pretty good and had potential, at least for learning stuff if nothing else. I've attached the schematic provided in another thread on our wonderful community.
    The problem is as follows: power LED comes on and that's it. Classic failed GPU I thought, so what I did, since it's broken anyway, I blasted it with some hot air to see what happens. It's at this point that other laptops manage to turn on, but this one didn't. I decided to probe around the motherboard with the help of the schematic and most of the voltages are there, except CPU Vcore. The caps under the CPU where this is supposed to be present, don't give any reading. Page 10 shows us that V Core is generated from VBATR CPU, which reads 19v, by Q505 thru to Q508. These are controlled by U506 ISL95831 on page 11, which I suspect is bad because: +5va is present, CPU_PWEN is also present. I don't have a scope sadly, which would've enabled me to probe the gates of those transistors to see if U506 pulses them. Do ISLs like that usually fail, or should I expect the GPU or something else to be defective....still, why is there no CPU Vcore ? Does it come on after the GPU initializes or something tricky like that ? :|
    Wattevah...
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP Pavilion DM4 6050A2402401 Motherboard no CPU Vcore
    first check whether there is a short in CPU Vcore circuit. If there is no short, measure voltage on all pins of U506 and report them here to check.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      I believe there's no short, but I shall check again and report.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        Ok, in case anyone is still out there willing to help, I measured one of the caps on CPU V core (say C236 on page 11) and I get around 13 ohms between it and GND with the CPU in place. If I remove the CPU, it goes up to 1 something kilo ohms, but the board doesn't turn on either without it and I believe 13 ohms is normal with the CPU in place.
        Wattevah...
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          yes. now, voltage values on all pins of U506 are important to check.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Ok but what exactly am I looking out for ? Some of them can't be measured by your standard DMM - a scope would be required which I sadly don't have, but I already checked what I consider to be "important" ones like the "enable" and VCC and stuff and they're all there...unless there's something else I should be looking out for. Adding to the difficulty is lack of a board view and the multitude of unmarked components, so it's impossible to follow the schematic past a certain point...
            Wattevah...
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              If you have VCC and Enable, it means the controller should turn on the power to the CPU. Since you say you do not have a short on any of the mosfets, replace the controller chip.
              A working TV? How boring!
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                Guess it's on to Ali to get some chips....wait a month then report back Meanwhile, what other causes there may be for this behaviour ? Truth be told, the laptop WAS reflown at some point, but shouldn't CPU Vcore still come on ?
                Wattevah...
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  I recommend replacing both the controller chip and the Mosfets.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    The FETs just for good measure ? I did not pick up low resistance anywhere on them, plus I believe something else would've popped on the board if they WERE shorted, though I could be wrong and some of the rails could still be "up" even with a shorted FET there....
                    Wattevah...
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      Hopefully someone's still around for this project. Here's what's happened: I replaced the ISL and tried firing it up. I DID get CPU V-core briefly and I thought I was all done. I put the board loosely on the case to try it with the display, I pressed the power button, the LED came on, then I heard like a hiss (the kind of noise inductors make), then the AC adapter shut down...not I have a short somewhere on CPU-Vcore AND GPU-Vcore...at least that's what the meter's showing me....diagnostics time. I hope the ISL itself didn't blow. I'm sure I soldered it correctly and I double-checked and triple-checked...Probably a MOSFET went...
                      Wattevah...
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        Q507 and Q508 shorted - removed them (VERY diffcult!) and now the short's gone....I'll try replacing them. Hopefully they don't blow again...can a bad CPU cause this ?
                        I really had to blast the hell out of those transistors with hot air until they finally came loose and since they're very close to the GPU, I have my doubts about whether this board is still good or not....I'll push on nevertheless...
                        Wattevah...
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          that is strange.
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            is there any solution to prevent such things from happening?
                            • piernov
                              • Jan 2016
                              • 4437
                              • France
                              I'd always recommend replacing the buck controller and the MOSFETs all in one go for high voltage supplies. One of the component dying will kill another. On low voltage it's not a necessity, but better safe than sorry.
                              However, if the MOSFET measure perfectly fine and they short right after replacing the controller, I'd guess this is more a case of bad soldering/bad controller or too much heat on the MOSFETs will replacing the controller with hot air. The MOSFET can be bad even if they measure perfectly fine, but it doesn't happen often.
                              When replacing the MOSFET you have to get them from a reputable source, as there are a lot of remarked components on eBay/Aliexpress from China. Also, if the buck converter has multiple high-side (or low-side) MOSFET it is better to have them matched or the current distribution can get unbalanced. Usually having the same batch number is fine. Even if only have died, all of them should be replaced. Even better if it's a multi-phase buck converter is to have all MOSFET on all the phases matched, but you usually don't have to be that pedantic. If one of the phase is getting hotter (or colder) than the others then the issue is most likely there though. When you buy them from a reputable supplier, you usually get the same batch. When buying on eBay/Aliexpress you get random components.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                Bad solder job on the controller...that makes me a bit nervous TBH, because I'm not entirely sure there aren't any pads that touch, at least as far as I can make out through my magnifier. It's a QFN and has no leads you can actually see, so a little luck has to go with it too, since you can't really see under there.
                                Too much heat: when I replaced the controller I don't think I blasted it THAT much TBH - the transistors themselves were far worse. I had my station at max 450C and even then it took like 5 minutes to remove ONE of them since they have that pad on the bottom, so with two removed, the other 2 still on the board took quite a beating...so did the graphics chip right next to them. THAT's what I'm most worried about ATM....
                                What I'll try first is to power up without the FETs and see if I at least get back to where I was, since I don't want to bother soldering them in and trash them immediately...if something is messed up, I should see smoke coming out of the IC or something...again, not 100% sure of my soldering there :|
                                Wattevah...
                                • piernov
                                  • Jan 2016
                                  • 4437
                                  • France
                                  When soldering a QFN you need to put good solder (not lead-free or Aliexpress specials…) on the pads, a decent amount. If there is a center pad, don't put too much solder as you'll have a hard time aligning the chip, but still some. Decent amount of flux as well.
                                  Then when with the hot air you start melting the solder, align the chip roughly but it should get somehow on the pads, and press down on the chip (trying not to lose the alignment) to make it sit flat on the board. Excess solder (on the pads or the center pad) will come out from the side.
                                  You'll have to run your iron on each side with some flux to get rid of the excess solder and to make the solder stick to the side of the chip (some of the area of the chip's pads is on the side).
                                  Check with a magnifier and good lighting if every pad is soldered and look good (round, shiny, no bridge, stick up a bit to the side of the chip). and that the chip sits flat on the board at the 4 corners.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    I'd give it an 8 out of 10, just because it took me a while to align it and it kept slipping off and running away as the solder melted...it turned out decent in the end I DID get Vcore for a short while, so I reckon the controller is fine. I'm worried the CPU may be damaged because when one of the "high-side" FETs shorted, it sent full adapter voltage into it....just a hunch...
                                    Wattevah...
                                    • piernov
                                      • Jan 2016
                                      • 4437
                                      • France
                                      Yes, if the high-side MOSFET shorted it can kill the CPU. If the low-side shorted then it's not an issue.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        Another nail in the coffin sadly...it was an i5 as well sadly Only luck can make this thing turn on now...that or a different CPU which I don't have...
                                        Wattevah...
                                          HP Pavilion Pavilion Laptop 14-dv2514sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2514sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2514sa boardview and Pavilion Laptop 14-dv2514sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-07-2024, 05:50 AM
                                          HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2504sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2504sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2504sa boardview and Pavilion Laptop 14-dv2504sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv0569sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv0569sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0569sa boardview and Pavilion Laptop 14-dv0569sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Pavilion Pavilion Laptop 14-dv2501sa Notebook 14 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Pavilion Laptop 14-dv2501sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2501sa boardview and Pavilion Laptop 14-dv2501sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
