Acer aspire 4141g internal display problem
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi friends, I need help on this.I have an acer aspire 4741g core i3 and nvidia graphics.the problem it boots fine and when i connected to external display comes ok.but when connected to original internal screen it shows 6multiple images,I tried replacing a screen with a good one it shows light but no image, already tried many different working screens still the same.but when i plugged back the original screen the same as before it shows 6multiple image.I have attached the image look of the screen.can someone please help on this and advise please. the first image is the original screen and the second image that is came from a working and good screen
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer aspire 4141g internal display problem
    Dear String2016, you have 900+ posts still you cant make it that this is bad graphics issue?? have you forgot famed hp dv2000/6000 nvidea giving same problem.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      @Mcplslg123 this is not a graphics issue my friend ill tried using external monitor display is good
        • 21304
        Did you connect to external monitor over VGA or HDMI
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I still beleive this is a graphics issue. You reflow the graphics chip and test display on internal screen
            • 21304
            @mcplslg123 , could a bad resistor at RN46 (0ohm) cause the same issue ,i`m just asking your opinion, i agree with you this case does look like a bad GPU
            • String2016
              • Nov 2015
              • 2238
              • philippines
              Before i reflowed im asking an advise for this,beacuse i still believe this is not a graphics issue because when i connect to external display display is nomal and good.only if i connect on internal screen the original have 6multiple display,but when i connected a working screen no image,sometimes screen becomes green,red.please anyone help on this
              • String2016
                • Nov 2015
                • 2238
                • philippines
                @Smdflea i coneected to external monitor both ports hdmi and vga testrd display is normal and good.this is not a graphics issue
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  Could still be GPU issue, sometimes it's good on external display but you won't have image or backlight on internal.
                  Some laptop won't recognize a non-original display. You'd have to swap the EDID ROM.
                  Also make sure the LVDS cable is good.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Good display on external monitor does'nt mean its not a bad gpu. Have seen a lots of Hp dv2000 with good display on external monitor and 4-6 split display on internal screen coz of bad gpu.
                    If you dont want to beleive that, thats your choice but i'll try a mild reflow of gpu first.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Not likely. The display wont split into 4 or 6 figures coz of this Rn
                        • 21304
                        Yes rn46 has nothing to do with it, my mistake.
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          but how come if i replaced a good working screen it does not show images?anything than reflow should i replaced first the lvds cable?
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            @mcplslg123 i think you are right i tested the original screen to another board it shows good image.does this mild reflow can last longer?
                              • 21304
                              Try it, then if it doesn`t work do a mild reflow as @mcplslg123 said .
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                which is better mild reflow to heat the chip under or upward?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Hardly matters how you reflow as it wont last beyond a couple of days. You need to either change the graphics chip or look for new mb as i've already said.
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    @mcplslg123 reflowed the graphics still the same issue it gives multiple display and no image on good screen if i replaced
                                      ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 02:30 PM
                                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-06-2024, 05:27 AM
                                      ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
