sony vaio pcg-51211l
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Hi friends, i need help on this sony vaio laptop there is a display on external but on the internal there is no backlight, when i checked on lvds connector someone remove a fuse i dont know what fuse it is, I have attached the image and here is the measurements of the lvds and i dont have schematic
    pin1=3.3v
    pin2=3.3v
    pin12=3.3
    pin13=3.3
    pin16=1.2
    pin27=1.7
    pin29=1.7
    pin35=1.7
    pin40=3.3
    the rest pins have 0v
    anyone can help me on this please
    • 21968
    Re: sony vaio pcg-51211l
    Schematic https://www.badcaps.net/forum/showthread.php?t=46618
    • String2016
      • Nov 2015
      • 2238
      • philippines
      Thanks for the response sorry my mistakes above here is the correct measurements
      pin1=3.3v
      pin2=3.3v
      pin12=3.3
      pin13=3.3
      pin16=1.2
      pin27=1.7
      pin29=3.3
      pin30=3.3
      is there a way to bypass F17 FUSE because other side have 19v and on LCDVCC on pin 29 and pin 30 it has only 3.3v and pin 30 connected to C296 caps no 19v also please help
      • String2016
        • Nov 2015
        • 2238
        • philippines
        need help on this please
          • 21968
          The fuse part number is 0466003.NRHF ,its in the schematic, its a 3A very fast blow. Do you have any donor motherboards
            • 21968
            Check R252 and C298 , on pin 11 DISPON
            • String2016
              • Nov 2015
              • 2238
              • philippines
              i have scrapboards but i cannot find the same fuse and i checked R252 has 5.5kohms and c298 0v and pin 11 0v
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                pin1=3.3v
                pin2=3.3v
                pin12=3.3
                pin13=3.3
                pin16=1.2
                pin27=1.7
                pin29=3.3
                pin30=3.3
                When the fuse is blown. how can there be 19v on lvds connector??
                19v will go thruogh the fuse only. Check resistance on both pins of fuse, if not shorted , you can put a jumper between both pins of fuse. This is for test purpose only. It is safer to put a fuse but atleast you can check by putting jumper.
                  • 21968
                  As mcplslg123 said, you can use a jumper, or even use a higher rated fuse temporarily. If you still get nothing on the display check U11 .
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    there is no 19v on lvds connector. i checked resistance to the ground on one side 0L and on the other side 0.552v.I already tried putting wire on both sides of the fuse to test but still the same issue
                      • 21968
                      pin1=3.3v
                      pin2=3.3v
                      pin12=3.3
                      pin13=3.3
                      pin16=1.2
                      pin27=1.7
                      pin29=3.3
                      pin30=3.3
                      pin 29 and 30 are ok. You should only put the jumper between pin 1 and 2 of f17 (VIN) . The lvds needs 19v on pins 8,9,10 only.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        i already done that i put jumper from the fuse pin 1 and 2 but still the same issue and no 19v on lvds connector pin 8910
                          • 21968
                          pin1=3.3v
                          pin2=3.3v
                          pin12=3.3
                          pin13=3.3
                          pin16=1.2
                          pin27=1.7
                          pin29=3.3
                          pin30=3.3
                          "because other side have 19v" .The other side of what have 19V , i assume you meant 19V on pin 2 of F17 before you put the jumper on ?
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            yes pin2 of F17 have 19v i put jumper on both sides of F17
                              • 21968
                              Ok ,so you have 19V on pin 2 before you put the jumper ACROSS from pin 2 to pin 1 of F17 pads. If you have 0V with the jumper then pins 8,9,10 or C292 is shorted
                                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:27 AM
                                Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                                This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                                Sony VAIO SVT1122I4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVT1122I4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVT1122I4E boardview and SVT1122I4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                                This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              • Carlos#2003%
                                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                by Carlos#2003%
                                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                02-15-2024, 07:52 PM
