ACER ASPIRE 5733 Voltage flactuating
  • String2016
    • Nov 2015
    • 2234
    • philippines
    Hi friends, I need help on this ACER Aspire 5733 LA-6582P PEW71.The problem with this is dead laptop when i check in bench lab it shows from 100miliams to 200 then goes down fluctuating.When i check on the dc in 19v ok and on the first switching mosfet PQ59 both sides have 19v but on the second mosfet PQ52 source side ok have 19v but on the other side which is drain voltage flactuate from 15v drom to 11v then goes to 15 and dropping,the same also on the resistor PR351 with a mark R020 both sides voltage flactuating from 15v to 11v. Anyone can help me please need advise on this please
    • 20788
    Re: ACER ASPIRE 5733 Voltage flactuating
    change PQ52
    • String2016
      • Nov 2015
      • 2234
      • philippines
      replaced pq52 same value mosfet but still the same on the 4pins drain side fluctuating voltage.anyone please help on this
      • String2016
        • Nov 2015
        • 2234
        • philippines
        i think i found the problem its U17 the isl chip is shorted ill try to replaced and feedback soon
        • String2016
          • Nov 2015
          • 2234
          • philippines
          still the same issue i replace isl U17 and tried again still the same issue voltage flatuate on PQ52 drain side.anyone can help me on this please
          • String2016
            • Nov 2015
            • 2234
            • philippines
            i change pq59 first mosfet i turns on then after i unplugged the charger it comes back to the same issue fluctuating voltage on pq52 can anyone please help me on this please
            • mielta
              • Apr 2015
              • 368
              Hi
              Remove PR351 and check voltage
              when it is stable you have an problem on B+
              when not check PC248 + PC249
              • String2016
                • Nov 2015
                • 2234
                • philippines
                I removed pr351 still the same problem fluctuating i checked pc248 and 249 caps no short
                  • 20788
                  Can you check PQ59 and PQ65
                  • mielta
                    • Apr 2015
                    • 368
                    Change or remove to test PC248 and PC249
                    you cannot messure that issue
                    • String2016
                      • Nov 2015
                      • 2234
                      • philippines
                      Check pq59 voltages fluctuating on pin2 and 3. Done test pc248 and pc249 by removing from the board the ceramic caps are not shorted
                      • mielta
                        • Apr 2015
                        • 368
                        have you checked without PC248/249 ??
                        • mielta
                          • Apr 2015
                          • 368
                          desolder PQ65 an check fluctuating
                          and Messure resistance from PR353-354-361-371 are OK?
                          • String2016
                            • Nov 2015
                            • 2234
                            • philippines
                            you mean i will removed pc248 and 249 and checked pq59?
                            • String2016
                              • Nov 2015
                              • 2234
                              • philippines
                              i removed pq65 and checked still fluctuating voltages i cannot find the resistor PR353-354-361-371
                              • mielta
                                • Apr 2015
                                • 368
                                yes remove PC248 and 249 and check flucation
                                • mielta
                                  • Apr 2015
                                  • 368
                                  PR353
                                  PR354
                                  PR361
                                  PR371
                                  see in schematics where the are
                                  • String2016
                                    • Nov 2015
                                    • 2234
                                    • philippines
                                    done test removing PC248 AND 249 and checked still voltage fluctuating. i have to find now where is PR353
                                    PR354
                                    PR361
                                    PR371 and already checked the schematics but i cannot find on the board i will check again
                                      • 20788
                                      Which side of PR351 did you test , pins1+2 or 3+4 .
                                      • Stevie2001
                                        • Apr 2018
                                        • 183
                                        • irland
                                        I noticed isl chip board give this common issue.
                                        Isl chip has 1pin gnd rest of the pin is not gnd do this get multi-meter put on continutiy mode and put black on gnd and swipe the red accross all pin of isl pins ignoring the gnd pin se if any pins beep if they do beep investigate from their were beep coming from track it.
                                        Make sure no power is on.
                                        Check isl datasheet for pin layout output.
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
