x72s GPU problem
  • killersoft
    • Apr 2017
    • 75
    • algeria
    x72s GPU problem
    Hello friends,
    I've a problem with my laptop Asus x72s gpu, the gpu is broken and i want to disable the gpu from motherbord to use integrated graphical cpu
    i'm here to ask you if i can do it by flashing bios?
    if yes i want the flash Bios of ASUS x72s
    Thank you
  • killersoft
    • Apr 2017
    • 75
    • algeria
    Re: x72s GPU problem
    • lazaro.089
      Asus Zephyrus M16 / GU603ZW problem
      by lazaro.089
      Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
      CPU: Core i9-12900H
      Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
      Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
      The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
      08-26-2025, 06:33 PM
    • AtelierRepa
      ASUS X712JA problem
      by AtelierRepa
      I have a problem with the bios, let me explain.
      With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
      I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
      My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
      The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
      06-15-2024, 04:33 AM
    • greg1985
      Asus dabkxmb18b0 rev.b bios problem
      by greg1985
      Hi. I bought a damaged Asus motherboard, model dabkxmb18b0 rev.b. The problem with the motherboard was a faulty processor.
      I replaced the processor, but it arrived without a BIOS chip. I found one post on the forum, but my problem is
      I don't know which chip to program, and I don't have a schematic. Does anyone know which BIOS chip models are compatible with this motherboard? If so, please let me know. Thanks.
      10-20-2025, 11:34 AM
    • boticario
      problem with asus tuf A17 FA707NUR
      by boticario
      I’m trying to recover an ASUS TUF Gaming A17 FA707NUR (Ryzen + RTX 4050, 2023 model).
      The laptop powers on, fans spin, but the dGPU (NVIDIA) is not properly initialized — sometimes it shows up in Device Manager with Code 43, sometimes black screen.
      After several BIOS downgrades/upgrades (versions 300, 301, 303) and EC resets, it thinking looks like the EC firmware (IT5570VG-256) might have a persistent fault or flag stored in flash.
      I already extracted the BIOS .CAP files and DXE sections with UEFITool and IFRExtractor, but I couldn’t find...
      10-18-2025, 04:37 PM
    • boticario
      by boticario
      10-14-2025, 08:38 PM
