Toshiba satellite C850 all usb ports not working
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Toshiba satellite C850 all usb ports not working
    i checked resistance on each pin with red probe on the ground there is no short and also on the data pins no short.can i try remove this ap2111 ic and test voltage on pin 6 and 7?
    • BlueMidnight
      • Jan 2015
      • 489
      I just need to clarify something. Terminology is important in this case. If you set your meter for diode mode, you aren't measuring resistance so much as you are measuring the voltage drop between the 2 probes of the meter when it outputs a tiny test current. We need to know if the voltage drop you measured on all those pins is approx. 0.5V. It should not be much lower and it should not be much higher.
      Earlier, you measured 2.7 ohms from the 5V output pin to ground. Is that still true? If you are reading 0.5V in diode mode on the same pin, then that indicates there is no short. Try measuring the resistance in both directions and see if it's the same. If one direction reads 2.7 ohms and the other direction reads infinity, then there is no short after all. Instead, you might have a meter with an unusually high test voltage it uses in resistance mode. It might be enough to forward bias the body diode of the FET inside the switch IC, and therefore show a low resistance in one direction.
      If there is no short, the IC is bad and must be replaced. If there is a short, then the IC should be remove to help find it. Either way, you may remove it now.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        thanks for the response bluemidnight, I checked again and measure the output on the chip in diode mode red probe to ground and black to pin 6 it shows 0.5v and on pin 7 0.5v also.Maybe this chip is bad,and also i check its usb port pins for bents but it is clear, and now i have problem i cannot find the same with this AP2111 chip on my scrapboard here available only G547E2 chip, Is it possible to replace with this?
        • BlueMidnight
          • Jan 2015
          • 489
          Okay that's good. That means we know the chip is bad and you don't need to go chasing shorts.
          You will need a chip that uses an active high enable signal. Unfortunately, the G547E2 uses an active low enable signal. You would need a G547E1 instead, or something from another manufacturer that performs the same function. The Richtek RT9711A would work. It has the same pinout, 2.5A max current, and an active high enable pin.
          • String2016
            • Nov 2015
            • 2238
            • philippines
            ok thanks i will try to find the chip replacement you mentioned.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              #26
              i cannot find any chip replacement that you mentioned in my scrapboard here all have G547E2,but i have found different chip with 2061 markings could it be the same?
              • BlueMidnight
                • Jan 2015
                • 489
                That appears to be a Texas Instruments TPS2061. Unfortunately, it won't work due to having an active low enable pin, and only a 1A current limit.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  #28
                  ok thanks im still finding the right chip
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    #29
                    I still cannot find the exact chip on my scrapboard , but i have found here its AP2301 but it has only 70mΩ resistance.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      Looks like that one is active low also. The AP2311 is the active high version.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        #31
                        i have here another scrapboard from acer it has a mark MM-G1 111581
                        • BlueMidnight
                          • Jan 2015
                          • 489
                          I'm not sure what that one is. But another way of finding out would be to look at the schematic for that Acer board.
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            #33
                            still i cannot find the same chip or the other replacement all the same with low enable signal.Is there a way to bypass this?
                            • BlueMidnight
                              • Jan 2015
                              • 489
                              It's possible to use one of those active low chips and connect a wire from pin 4 to ground. However, the USB ports will probably be powered at all times, as long as the notebook is plugged in or has a battery.
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                #35
                                ok thanks for the response ill that and feed back soon
                                • BlueMidnight
                                  • Jan 2015
                                  • 489
                                  Thinking about it.. an even better option may be to do the same thing except bend pin 4 up (and/or place an insulator underneath) so it doesn't even touch the pad when you connect the pin to ground. That way it doesn't matter what unknown circuitry might be at the other end driving that signal.
                                  • JaroTech
                                    • Mar 2015
                                    • 351
                                    Why not invert the enable signal with a transistor and a resistor?
                                    • BlueMidnight
                                      • Jan 2015
                                      • 489
                                      That's a good question. And I think it all comes sown to practicality. If someone wanted to go out and buy a part, they could just buy the correct IC in the first place. And if they want to check scrap boards for the perfect transistor, that's going to be a lot of work (trying to find datasheets for each one to see if they are appropriate). And then 2 resistors would have to be found for the biasing and current limiting. And then they would all have to be mounted to the board in some way. And either the trace would have to be cut or pin 4 would still have to be bent upward...
                                      Impossible? No. But not as simple of a solution as it is on paper.
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        #39
                                        thanks for the response i still not do it because i'M hoping i can find the same chip, if not do you mean i will not soldered the pin 4 of the ic on the board and bend upward and connect a wire to the ground?
                                        • BlueMidnight
                                          • Jan 2015
                                          • 489
                                          It's probably fine either way. But we don't have the schematic. So yes, the safest thing is to connect ground to pin 4, but bend the pin up carefully so it can't affect (or draw current from) the rest of the circuit.
                                            Toshiba Satellite L50D-B-11V Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite L50D-B-11V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L50D-B-11V boardview and L50D-B-11V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Z30t-A-10C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Z30t-A-10C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30t-A-10C boardview and Z30t-A-10C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            Toshiba Satellite Satellite C55-A-1R8 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite C55-A-1R8 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite C55-A-1R8 boardview and Satellite C55-A-1R8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
