ASUS K42F weird problem.
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello tech.mates!!!
    i just wanna ask for help about this weird problem of mine..
    i got a asus k42f laptop w/ i3 cpu with no display at first. then i flash bios and its works and i notice keyboard is not working fine then.
    i was replaced the keyboard cos some keys are not working. then now it works.
    after a week it comes back to me and client says that the keyboard was not working and its typing character by it self. so i replaced it with another one.
    but the problem is still the same. its typing by it self even i disconnect the ribbon of keyboard to the mainboard.
    i used usb keyboard but it still the same.
    i also think it might be bios issue. but it was not cos i already tried to flash the bios 2nd time.
    any idea would releave my stress.
    tnx in advance.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: ASUS K42F weird problem.
    first of all check keyboard connector and SIO.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      your problem is not in the bios replaced SIO chip solve your problem
      • rickybucalan
        • May 2013
        • 322
        • philippines
        looks like hard to do. i never done that before.
        saan ba location mo boss string2016 i reffer ko na lng sau?
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          If it is your first SIO replacement, I recommend you practice it on an scrap board first. then, do it on this board.
          • lazaro.089
            Asus Zephyrus M16 / GU603ZW problem
            by lazaro.089
            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
            CPU: Core i9-12900H
            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
            08-26-2025, 06:33 PM
          • AtelierRepa
            ASUS X712JA problem
            by AtelierRepa
            I have a problem with the bios, let me explain.
            With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
            I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
            My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
            The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
            06-15-2024, 04:33 AM
          • lukkihapsi
            Asus Vivobook X515JA Weird Boot Issue
            by lukkihapsi
            Asus Vivobook X515JA Laptop
            Issue :
            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
            Tried :
            Cleaned inside for dust, applied fresh thermal paste. No Change!
            Removed keyboard, Trackpad, fingerprint sensor. No Change!
            Removed Internal SSD. No Change!
            Updated BIOS to latest version. No Change!
            Removed battery and pressing power button for 1 minute. No Change!
            Weird Part :
            Upon turning laptop ON, screen lights up - stays black,
            I...
            07-07-2025, 12:07 PM
          • Dobrowol
            Asus GA402RK keyboard and kb backlight problem
            by Dobrowol
            Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
            04-28-2025, 04:30 PM
          • RotVik
            ASUS PRIME B550M-A AC weird behavior
            by RotVik
            Hello, I need a little help
            I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
            I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
            05-01-2025, 04:59 PM
