help : hp 14 m/b : DAR62CMB6A0
  • bigbily09
    • Dec 2014
    • 68
    • qc
    i have a hp 14 laptop
    m/b : DAR62CMB6A0
    The problem was with power but display on screen.
    i tried bios reprogram first but still no luck , and as far as i troubleshoot the motherboard. i check the coils 3.3.v is present but the 5v is not. so i download a diagram. then i see that the ic controls the 5v 3v is pu10 and pu9 . after testing some pins of pu10 i see that the 5v ic is only outputting 2v and the pu10 is heating much.
    after that replace pu10 and pu9 but still no luck. still ic is heating
    please help
    heres the diagram i use
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: help : hp 14
    check small capacitors near kbd connector. Mostly it goes bad in this particular mobo and its connected to 5v line. Very likely this will resolve your problem as i have got exact problem in atleast 3-4 R62 mb.
    I dont remember the capacitor number, If you cant find out i can give you the exact number but tomorrow.
    Try and update about results,if any
    • bigbily09
      • Dec 2014
      • 68
      • qc
      Re: help : hp 14
      sir i cant find kbd connector
      sir can you pls highlight the location you replace caps
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: help : hp 14
        Measure resistance to ground on PIN7 of PU10 or PJP4 and post results
        • mcthr
          • Aug 2019
          • 25
          • Philippines
          Re: help : hp 14
          can anyone help i have hp 14 to good current but the currrent is always getting high.. no display issue i flash already bios but same issue ty...
          • Sephir0th
            • Oct 2020
            • 1283
            Re: help : hp 14 m/b : DAR62CMB6A0
            "Good current but current is always getting high"
            Explain please
            FairRepair on YouTube
            • hs5424
              Dynacord powermate 1600 block diagram.
              by hs5424
              Hi All,
              I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
              The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
              07-31-2025, 01:35 PM
            • EasyGoing1
              The best way to drive a heating element?
              by EasyGoing1
              I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
              What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
              This is the general setup that I have now.
              This is what the...
              01-25-2023, 11:29 AM
            • Cemal Odabasioglu
              MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
              by Cemal Odabasioglu
              I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
              Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
              Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
              Observations...
              01-14-2025, 03:54 PM
            • gabri2211
              I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
              by gabri2211
              hello everyone, I'm looking for the wiring diagram of this led monitor.
              the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
              I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
              I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
              thanks to those who will answer
              12-10-2024, 04:37 PM
            • sew333
              Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
              by sew333
              Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
              So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
              So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
              I expect that i will pay more for bills. But i wanna know this. Will using electrical...
              06-14-2024, 07:30 AM
