Acer Aspire 5252 not turning on, 18v on power button
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Hello, i have this board that's giving me trouble. Acer Aspire 5252 UMA with LA-6552P mainboard.
    Original problem was EC shorted. After replacing EC, southbridge was getting very hot. I replaced Southbridge. Nothing getting hot but no power either, and i have 18V on the power button.
    3.3V ALW, 5V ALW and 1.1V ALW are all present. EC crystal is oscillating. EC_RSMRST# is 0.62V, so i suspected maybe the southbridge i put on there is not good. This is the 3rd southbridge i replace, and it came from a board that did turn on. Before i took the SB from it i also cross-swapped EC between both boards and the other board still turned on while this did not.
    Have also tried many BIOS dumps and several chips - no go. Any help appreciated.
    A working TV? How boring!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Acer Aspire 5252 not turning on, 18v on power button
    Also the battery is not charging, orange light not coming on, charger IC does not get enable on pin 3 from EC.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      This has nothing to do with southbridge, EC is not giving EC_ON command on pin 102. It would be nice if i could find out why.
      • piernov
        • Jan 2016
        • 4435
        • France
        Annoying one indeed. Apparently the EC doesn't do what it's supposed to. First check soldering, you never know…
        Then check voltage on VCC, AVCC, ECRST# and EC_ON pins of the EC.
        Check the resistances connected to the SPI ROM, check voltage on all its pin. Make sure you flashed it with a good dump.
        I hope this should be enough to get any reaction from the EC.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Fixed it, resistor between CLK pin of SPI chip and EC was missing. Must have knocked it off at some point.
          However, now the board turns on then back off after a short while, no video signal. This sucks. Some power rails are not starting up, SYSON signal does not go high, it stays at 0.18V. PM_SLP_S3# and PM_SLP_S5# are ok.
          • piernov
            • Jan 2016
            • 4435
            • France
            What about SUSP#?
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              SUSP# was good. Changed EC (again), actually went back to the other one i had on there. SYSON signal now ok, board powers on and stays on, still no video. Looks like i will have to replace NB as well.
              • piernov
                • Jan 2016
                • 4435
                • France
                Well, that's an RS880M so it wouldn't be surprising.
                Is it no display or no POST though?
                If no display, check with external, but chances are the nortbridge is bad.
                If no POST, check the usual stuff: CPU VCore and other S0 rails, CPU reset signal and activity on BIOS CS pin. Make sure the CPU and RAM are good and compatible with the board.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Have Vcore. Had it before as well, when the SYSON signal was missing. CPU and RAM are the ones that were on it, tried others, no change. No VGA output either. Will replace NB on monday and keep you posted. The donor board that the last southbridge came off has not been reflowed or messed around with in any way, so it should be good.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    Replaced NB, still no go, but that one could well be dead, too. Here's where it gets interesting tho: The sound chip was heating up as well, so i replaced that too, still no dice.
                    Bought another broken laptop today, complete with everything except battery, for about half the price of a working board. The lady who sold it to me told me that her daughter was playing games in bed. Typical.
                    So, i put the original northbridge from the client's laptop on this new board. I did keep track of what chip went where. Surprise: Not working! Again, this board had been never repaired and the original issue was EC shorted out. Then i reballed the northbridge that was initially on this other board, put it back on and lo and behold, it runs.
                    Then i tested the parts that were on the original board on this reballed one. Turns out that on our client's laptop, the RAM is dead too, and the LCD has no backlight. Only the CPU is still working... Not the kind of thing you'd like to see after you've put that many hours (and $$) in it.
                    So, to recap, what's blown on this laptop:
                    SB, NB, EC, ethernet chip, sound chip, charging chip, RAM and LCD.
                    The mention of the ethernet chip being fried should ring a bell to some of you - this has likely been zapped by lightning thru the ethernet port, and here you have the extent of the damage. This one is long past economical repair.
                    • Djosla
                      • Dec 2012
                      • 246
                      • Montenegro
                      haha what a nightmare,trust me i know exactly what you have gone trough,now i suggest a vacation and an icecrem...
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        The inverter is what had failed on the screen (no, it's not the fuse ). I didn't even know there was a model of this laptop with a CCFL screen! It is a 15.6" CCFL screen. Of course, i don't have any compatible inverter, and it is built with a single IC so there's nothing to fix.
                        I fitted the LED screen with the LVDS cable from the laptop i bought. That takes care of that. Then... This laptop came with one hard drive inside with the caddy and everything, and another hard drive alongside it. Well, both HDDs are mechanically damaged. One will lock up before attempting to boot, the other will try to boot Windows 7 which seems to be installed on it, and get stuck.
                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 03:28 PM
                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:30 PM
                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                          09-06-2024, 05:27 AM
                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
