acer aspire one d270 no display
  • String2016
    • Nov 2015
    • 2236
    • philippines
    Re: acer aspire one d270 no display
    i dont see anything bad capacitor and hot components
    • String2016
      • Nov 2015
      • 2236
      • philippines
      update i change filter capactor PC58 and PC46 with tantalum caps 157uf 6.3v now netbook turn on and the display steady now for 3 hours i will test this for a couple hours and see what happens
      • String2016
        • Nov 2015
        • 2236
        • philippines
        update:tested for 4 hours and now issue still came back notebook turns on display comes then after a minute goes off again anyone please help
        • String2016
          • Nov 2015
          • 2236
          • philippines
          any advise and help on this please
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            when you replaced the caps and got steady display for 3 hours, was the laptop using only the charger without the battery?
            • String2016
              • Nov 2015
              • 2236
              • philippines
              #26
              yes the laptop using only charger without battery
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                #27
                if you have got an oscilloscope, monitor the voltage on the replaced caps to discover fluctuation.
                • String2016
                  • Nov 2015
                  • 2236
                  • philippines
                  #28
                  i dont have oscilloscope now i change again the two caps but this time 220uf 6.3v tantalum laptop starts display ok but this time 30mins only the display goes off and also i checked pc58 negative side of tantalum no voltage positive side have 3.3v and same on pc46 negative side 0v and positive side 5v. what could this be the problem?
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    #29
                    try depleting static electricity from the board.
                    It may help.
                    • String2016
                      • Nov 2015
                      • 2236
                      • philippines
                      #30
                      i already done that but still the same issue when display goes off
                      • String2016
                        • Nov 2015
                        • 2236
                        • philippines
                        #31
                        any help on this please
                        • String2016
                          • Nov 2015
                          • 2236
                          • philippines
                          #32
                          anyone help on this please
                          • caspian
                            • Oct 2015
                            • 1589
                            • Laptop
                            #33
                            using only the charger, after the screen turns off, go to connection CN17 and report voltage on pins 1 to 25.
                            • String2016
                              • Nov 2015
                              • 2236
                              • philippines
                              #34
                              thanks for the response caspian update i reflowed again the chipset and around pu3 area and pu7 area and put notebook cooler at the buttom now notebook boost fine so far its 5hours charger only plugged display not goes off ill keep testing a couple of hours more
                              • String2016
                                • Nov 2015
                                • 2236
                                • philippines
                                #35
                                now notebook is working tested for a couple hours battery and charger plugged in working thanks for the response
                                • caspian
                                  • Oct 2015
                                  • 1589
                                  • Laptop
                                  #36
                                  please report if the fault come back again.
                                  • String2016
                                    • Nov 2015
                                    • 2236
                                    • philippines
                                    #37
                                    ok caspian till nw still testing but seems fine for a almost 12 hours I also test battery only and battery and charger plugged in but it seems fine now i put notebook cooler at the buttom
                                    • String2016
                                      • Nov 2015
                                      • 2236
                                      • philippines
                                      #38
                                      update notebook is working and display not goes off anymore thank you all for the response
                                      • caspian
                                        • Oct 2015
                                        • 1589
                                        • Laptop
                                        #39
                                        since you reflowed the PCH, it is interesting to know how many months it will last.
