acer aspire one d270 no display
  • String2016
    • Nov 2015
    • 2238
    • philippines
    anyone help on this acer aspire one d270 laptop turns on display after a second no display and fan stops but led light steady\
    i have already replace memory, reflow chipset and cpu and reflash bios but still the same issue turns on display then a seconds no display. any help please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: acer aspire one d270 no display
    update i flashed back to original bios dump and reflow chipset again and pu3 laptop turns on display with battery only inserted turns on 30mins with display ok and after 30mins the display gone but fan spinning. but if charger and battery inserted turns on display but after a minute display gone but if charger only inserted wthout battery turns on but no display. any help please
    • String2016
      • Nov 2015
      • 2238
      • philippines
      any help on this please
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        remove the battery and use only the charger.
        turn the laptop on and measure voltage rails on coils.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          thanks for the response ive already measured coils charger only plugged in only PL7 have 0.50v both sides and also PL10 other side 1v and other side 0.22v. any advise please
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            what about PL5 and PL8 and PL9?
            • String2016
              • Nov 2015
              • 2238
              • philippines
              PL5 both sides 1.05v, PL8 both sides 1.06v and PL9 other side 1.16v and 1.15v
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                they seem OK.
                measure resistance on PR133 and PR155.
                now measure voltage on R459 after turning on.
                • fddizon
                  • Sep 2011
                  • 555
                  • Philippines
                  try replacing filter capacitors PC46 and PC58 with tantalum caps take from USB port.
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    thanks for the response i cannot find the r459 located
                    • String2016
                      • Nov 2015
                      • 2238
                      • philippines
                      @fddizon thanks for the response kabayan i just want to ask what value of tantalum caps?
                      • fddizon
                        • Sep 2011
                        • 555
                        • Philippines
                        Should be 220uf 6.3v
                        but you can try 147uf 6.3v coming from USB caps
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          @caspian PR155 1.0ohms and pr133 0.09ohms
                          • String2016
                            • Nov 2015
                            • 2238
                            • philippines
                            @fddizon i cannot find 147uf 6.3v but i have here in scrap board 157uf 6.3v and 227uf 6.3v which should i try?
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              with charger only, do you hear it booting into windows?
                              with charger and battery, do you see it booting into windows?
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                with charger only acer logo shows then a second goes off and with charger and battery the same issue but sometimes it boots to windows then goes off the display but fan is spinning with battery only boots on windows sometimes it takes 30 mnutes ok then display goes off when turn on again there is no display
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  what do you see on external monitor?
                                  If nothing, then do the following method:
                                  In each one of the three cases, when the display goes off, click on something that makes Windows to play a sound such as a music.
                                  then, discover if Windows is still active.
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    ill tried that external display the same as charger only plugged in boots then a seconds display off
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      update if i rest the netbook for an hour it turns on display ok but after 30mins still goes off
                                      • caspian
                                        • Oct 2015
                                        • 1591
                                        • Laptop
                                        do you see any bad capacitor or anything hot on the board?
