HP 255 G2 - No Video
  • b171331
    • Oct 2014
    • 15
    • SRB
    Hi.
    I got HP 255 G2, Board is osamu2-dis_kb_hpc mv_mb_v1 , HP Bios ID is 02191.
    When i start the laptop current is 350 mA, after 3 seconds drops to 220 mA and stays there. No image on screen. Board looks clean, no water damage.
    I replaced ram and flashed bios (used bios that ala_borbe
    aka Donald uploaded here) , nothing changed.
    Any help in diagnosing this would be appreciated.
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: HP 255 G2 - No Video
    check run voltages on coils,maybe some burned fet,coil or voltage regulator
    • b171331
      • Oct 2014
      • 15
      • SRB
      Got voltages on all coils, 16,4v on battery coil, 0,78v and 0,89 on cpu coils.
      Other coils on board 3,35v , 5,15v , 1,52v , 0,95v , 1,79v
      I don't have schematic to see correct voltages.
      • fester
        • May 2017
        • 158
        • Slovakia
        can you turn it on and off with power button or it turns on automaticaly after connecting power?
        • b171331
          • Oct 2014
          • 15
          • SRB
          On and off with power button.
          If i leave it on, cpu gets hot,fan start to spin.
          • fester
            • May 2017
            • 158
            • Slovakia
            first,try it with external monitor,if still no picture then is problem in graphic chip.
            • b171331
              • Oct 2014
              • 15
              • SRB
              No video on external monitor.
              Only one chip on board, AMD APU EM2100ICJ23HM.
              • fester
                • May 2017
                • 158
                • Slovakia
                have you tried it with disconected internal lcd?without schematics you cannot do much more..looking at every part under microscope and measuring every capacitor is lost of time in this case.
                • Udemzy
                  • May 2017
                  • 161
                  • Guatemala
                  You can't do much, I'll suggest you do a reboil on the vga chip.
                  • f-bone
                    • May 2013
                    • 96
                    • Greece
                    I replaced the CPU on the same motherboard (BIOS rewritten etc) - all voltages present, still no image. I see that the LVDS connector is missing 3.3V coming UB3 mosfet (other side near FAN connector). Any fresh ideas?
                    • hispeck
                      • Aug 2015
                      • 258
                      • nigeria
                      Hello Fester, i have same laptop, mine will turn on fan will move and stop then start again the second time but this time very fast, no display i cant even turn it off
                      • tonix
                        • Feb 2018
                        • 6
                        • zimbabwe
                        try changing the gpu it must be the problem
