Acer Aspire 5742G - no power up
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    I have problem with my notebook - won't start , only clicking sound is heard from motherboard. PL28 was shorted to ground - +3VALWP rail.
    I lifted up one side of this coil (side marked as "2" in schematic), sound stopped, and also PJ6 jumper, but short persist. I mean RT8206BGQW is bad , pin 30 - VOUT2 is shorted to gnd.I think correctly?
    Can someone help me with this?
    Thanks!
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Acer Aspire 5742G - no power up
    give me the voltage in all pins of RT8206BGQW -write it in photo -above incuded
    lader my english is bad
    • DeniS182
      • Jun 2014
      • 328
      • Slovakia
      Measured with lifted up one side of PL28 (side marked as "2" in schematic) , and also PJ6 jumper.
      RT8206BGQW:
      1 - 2V
      2 - 2V
      3 - 4.966V
      4 - 10V
      5 - 0V
      6 - 19.38V
      7 - 5.07V
      8 - 0V
      9 - 0V
      10 - 0V
      11 - 0V
      12 - 1.968V
      13 - 0V
      14 - 4.561V
      15 - 0V
      16 - 0V
      17 - 4.554V
      18 - 0V
      19 - 5V
      20 - 0V
      21 - GND
      22 - 0V
      23 - 0V
      24 - 4.554V
      25 - 0V
      26 - 0V
      27 - 2V
      28 - 0V
      29 - 0V
      30 - 0V
      31 - 1.327V
      32 - 5.06V
      • mielta
        • Apr 2015
        • 368
        HI
        Check PQ48 it can also have bin shorted.
        • DeniS182
          • Jun 2014
          • 328
          • Slovakia
          hi,
          PQ48 is not shorted.
          • ridamouh159
            • Nov 2014
            • 365
            • maroc
            Try to change the RT8206B if you haven t any short-circuit in the around of him
            and no short-circuit in the picture included here
            but be sure that your replacement circuit is new or worked sure
            • ridamouh159
              • Nov 2014
              • 365
              • maroc
              good chance
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                Probably Solid or tantalum capacitor have shorted
                • nasrojee
                  • Apr 2017
                  • 3
                  • DeniS182
                    • Jun 2014
                    • 328
                    • Slovakia
                    I lifted up RT8206B and short circuit persist. There isn't shorted components near this IC. Do you have any idea please?
                    • DeniS182
                      • Jun 2014
                      • 328
                      • Slovakia
                      • DeniS182
                        • Jun 2014
                        • 328
                        • Slovakia
                        at the end I bought new motherboard (second hand). Model is the same - NEW70 LA-5891P. But I found one difference. Connector in which is power button connected is on other place. - JLED1 and JLED2. But I have also problem with this motherboard, wan't to post. Only fan is running, led brights, but screen is black. I tried another cpu Intel i3-370m, another RAM, but nothing changed. Have someone bios file for this board? Thanks for any answer.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Try
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Is the pch same?? Check whether its Hm55 or Hm65?? If its Hm65 , 1st gen intel wont run.
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              both the boards have got the same revision number and the same production date. So it is not expected they have major differences on PCH and BIOS.
                              To make sure, check whether they have got the same PCH model.
                              • shuc
                                • 30
                                • Romania
                                Your new second hand motherboard come from Packard Bell laptop... I don't know the exact model (if I'm not wrong, it's EasyNote TM85)...
                                • DeniS182
                                  • Jun 2014
                                  • 328
                                  • Slovakia
                                  Chipset is same - HM55, GPU also. I tried it on external monitor, it post's but look what was on LCD. Internal lcd was black.I mean this is GPU problem and I need to do reflow/reball.
                                  • DeniS182
                                    • Jun 2014
                                    • 328
                                    • Slovakia
                                    After reball notebook works fine. But after some time, notebook won't charge battery. When adapter is connected on bar is written Connected, charging and battery is still on 26%. I replaced charger IC ISL6251 from other motherboard, but problem persist and on pin DCIN is 0V.
                                    • DeniS182
                                      • Jun 2014
                                      • 328
                                      • Slovakia
                                      I tried other battery, adapter, checked mosfets, but nothing changed.
                                      • DeniS182
                                        • Jun 2014
                                        • 328
                                        • Slovakia
                                        isl6251:
                                        Pin 7- 0.2V
                                        PIN 19 - 19V
                                        PIN 20 - 19V
                                        On other pins is 0V
