Sony HK5 DA0HK5MB6F0 MBX-269 Rev.F
  • VHSFI
    • Mar 2011
    • 47
    • Portugal
    I have a problem with this mainboard, original problem was PU101 very hot and no system response, after replacing it with a new one voltages started to appear but no response to power button, replaced EC controller, now after power button press the power led and battery led light up and then turn off and the system doesn't start.
    Bios has been reflashed same symptom, also EC controller was replaced to another new one and same symptom. Battery charges ok.
    Here are some measured values:
    Before Power Button Press:
    EC_WAKE_ON = 0v
    DEEP_EC_EN = 0v
    RTC_RST# = 3v
    RSM_RST#= 0v
    SRTC_RST#= 3V
    PM_BATLOW#= 0v
    S5_ON= 0v
    AC_PRESENT = 3.3v
    PCH_PWROK_EC = 0v
    +3V_WAKE= 0v
    +5V_WAKE= 0v
    +3V_S5= 0v
    +5V_S5= 0v
    15VPCU= 0v
    +3V_SUS= 0v
    +3V_S5_DSW=0v
    DEEP_EN=0v
    SUS_ON=0v
    After Power Button Press:
    EC_WAKE_ON = 3.3v
    DEEP_EC_EN = 3.3v
    RTC_RST# = 3v
    RSM_RST#= 3.3v
    SRTC_RST#= 3V
    PM_BATLOW#= 3.3v
    S5_ON= 3.3v
    AC_PRESENT = 3.3v
    PCH_PWROK_EC = 0v
    +3V_WAKE= 3.3v
    +5V_WAKE= 5v
    +3V_S5= 3.3v
    +5V_S5= 5v
    15VPCU= 14.5v
    +3V_SUS= 0v
    +3V_S5_DSW=3.3v
    DEEP_EN=13.3v
    SUS_ON=0v
    Some other important signal i am missing ?
    From my understanding shouldn't SUS_ON get high to turn on the remaining voltages ? Some signal missing before that can happen ?
    Any tip is appreciated.
    Thx in advance.
  • iXgrek
    • Aug 2016
    • Ireland
    Re: Sony HK5 DA0HK5MB6F0 MBX-269 Rev.F
    Hi. If you still need a hint with this particular board, you need to program EC with good, not corrupted file. I'm suffering same symptom, currently looking for EC file for it.
    To program it you will need one of those "vertyanov" or "svod" programmers. Available on ebay.Really good investment even as hobby. But remember - choose it wisely.
    • abdulhalim933
      • Oct 2015
      • 14
      • damascus
      Have you solve the problem??
      I have the same mb ..
      • digitalpc
        • Jun 2016
        • 305
        • .DLL
        check voltage of cpu after press power button any voltage
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
          09-06-2024, 05:30 AM
          Sony VAIO VGN-TZ31WN/B TZ Specification for Upgrade or Repair
          This specification for the Sony VAIO VGN-TZ31WN/B can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-TZ31WN/B boardview and VGN-TZ31WN/B schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
