Late 2013 macbookpro retina 13 water spill
Re: Late 2013 macbookpro retina 13 water spill
It dry very fast leaves no residue. Most likely is carcinogenic so you do not what to breath it very long. CRC LECTRA CLEAN HEAVY DUTY ELECTRICAL PARTS LIQUID DEGREASER, 19 OZ AEROSOL CAN, CLEAR
This one is non-flammable you can read up on it. http://crcindustries.com/ei/product_....aspx?id=02018Last edited by keeney123; 11-03-2016, 03:17 PM.Comment
I took my board, a multi-meter and microscope camera with me on a trip and finally discovered a short on the PP3V3_S0 rail. After the U8030 SO switch, the short starts. I don't know what item is causing the short as I do not have my tools with me to pull them out but took a picture of the switch which looks as if something happened here. . What do you think? Is the yellowish color just oxidation or could it be a cause of a short as well?Comment
by Gigabit2I have acquired this Apple MacBook Pro 15" Retina i7 2.3Ghz 16GB Late 2013 and it is not powering on. No lights on charger and no chime.
Inspecting the unit shows liquid damage, indicators have gone red.
Can somebody help me to diagnose and repair the unit or where I should start?
Thank you all. -
by tulekiI have a Macbook pro retina late 2013, i7/2,8ghz. That got some water on it.
Had water in my messenger bag, along with my mac in a cloth sleeve. And the water had sipped out during the night.
The sleeve was quite soaked a few inches in on one long side. So the liquid or moistur mostly went to either on the side with the trackpad, or the dislay side where the vents are.
So here's a recollection of what I've checked and looked at.
(I know, probably did a bunch of mistakes, and I'm kind of novice so bear with me).
When I took it out, I think the... -
by Gigabit2Hi all,
I have a MacBook Pro Late 2013 Retina.
When plugged in, it shows an orange light on the charger (without battery connected) and the fans spin. But after about 15 seconds they stop and then never spin up again. No chimes and nothing on the display.
There is impact damage to the corners of the casing and one of the USB ports is therefore warped. But the logic board itself looks okay from visual inspection.
PPBUS_G3H showing 12.58V at all times.
Can anyone help? -
by Reda123456MacBook Pro (Retina, 15-inch, Late 2013)A1398
I need bios for this macbook-
Channel: BIOS Requests ONLY!
Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
2/ Figure 1 Gfx-D500-B Front Facing
3/ Figure 2 +5v supply (zoom-in)
Intro:
While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...12-07-2023, 09:55 PM - Loading...
