Sony VGN-N530E MS72 MBX160 no power
  • tiak
    • Sep 2013
    • 50
    • Iran
    Hi,it's completly dead board,voltages:
    PF1,PQ1,PQ2 and PQ3 -> 19.5
    MAX1909:
    Pin1 ->18.5
    Pin3 ->4
    Pin 16,17 and 18 -> 0.0
    Pin 20,22 and 23 -> 18.7
    Pin 24,28 -> 19.5
    TPS51120: Pin 22 ->0.0
    What is the problem you think? Max1909?
    Thank you
  • tiak
    • Sep 2013
    • 50
    • Iran
    Re: Sony VGN-N530E MS72 MBX160 no power
    Hi
    any idea?!
    • relax79
      • Jul 2014
      • 51
      • TURKEY
      That means there is no "DCBATOUT" PQ2 drain.You must be check DCBATOUT to gnd short or not, if its not short you check pq1 and pq2 for short "g" gate pin to own "d"drain or "s" source pin. And check MAX1909 pin 6 ACOK, it is must be high about 3v. MAX1909_LDO is also very important device datasheet page 13 "Device Power Supply. Output of the 5.4V linear regulator supplied from DC IN"
      • ozy
        • Jun 2009
        • 44
        I know this is an old thread but just for reference just had a vgn-n21e (rev1.1) that was totally dead and suspected max1909, turned out to be a short 10uf 25v ceramic (pc106) on the dcbatout line.
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
          Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
          This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
          09-06-2024, 05:30 AM
          Sony VAIO VPCEA3S1E/V Specification for Upgrade or Repair
          This specification for the Sony VAIO VPCEA3S1E/V can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VPCEA3S1E/V boardview and VPCEA3S1E/V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
