Acer Aspire 5810T Completely dead, no lights at all.
  • Andreasbest
    • Aug 2014
    • 1196
    • Hellas ( Greece )
    Re: Acer Aspire 5810T Completely dead, no lights at all.
    So nothing more we can do about it.
    Do you think the problem is on the motherboard or miniboard?
    They are both really cheap to ebay.
    • BlueMidnight
      • Jan 2015
      • 489
      It looks like it's the main board that is the problem. That doesn't mean it's the only problem, but it's definitely a problem.
      For the mini board... you can actually test the 3V/5V on it by disconnecting it from the main board. Then plug in the power and press and hold the switch SW2. You should get voltage from the main 3V/5V outputs as long as the switch is being held down.
      • Andreasbest
        • Aug 2014
        • 1196
        • Hellas ( Greece )
        I found the 3V at SW2 but not on PIN 53 of BTB1 (with switch pressed and not)
        I also noticed something else, the miniboard became really hot and more spicifically the U115 a Atheros (!) ic!
        When i attach the mainboard it's cool, is this normal?
        • BlueMidnight
          • Jan 2015
          • 489
          With the switch pressed, there is supposed to be 3.3V at L24 and 5V at L25.
          If the main board is attached it will continue to force the 3V/5V_EN line to 0V, even if you are pushing the button. That turns off the main 3V/5V outputs and the LAN IC no longer gets power so it no longer gets hot.
          That IC should definitely not ever be getting hot enough to notice, so is probably bad. I thought you had checked L24/L25 for shorts though. Is one of them reading as shorted now? If you are sure it is that chip getting hot (and not just something right next to it), it needs to be removed. Then see how the board behaves.
          A short in the 3V or 5V rails might cause the 3V/5V chip turn both those rails off, but it doesn't really explain the 3V/5V_EN signal being 0V. There may be multiple problems.
          • Andreasbest
            • Aug 2014
            • 1196
            • Hellas ( Greece )
            No shorts to L24/L25, i get both voltage with the switch pressed and the IC is getting extreme hot.
            Do you think this is the only problem or we have problem in main board too?
            • BlueMidnight
              • Jan 2015
              • 489
              It's acting like it has a problem on the main board also.
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                #27
                Is there a chance the whole system to stay off as a kind of protection against the overheating/faulty ic?
                • BlueMidnight
                  • Jan 2015
                  • 489
                  Unlikely. That's the job of the 3V/5V chip. The EC would have no knowledge of that. And since the outputs are staying on when you press the button, the 3V/5V chip doesn't even see the problem.
                  It's more likely that a single event damaged more than one thing on the board. For example, if there were a power spike on the main 3V rail, it could damage the LAN chip and also the EC. I actually have a board here with me that has that exact problem.
                  You can try removing the LAN chip and see what happens though. It's not like you can make it worse at this point.
                  • Andreasbest
                    • Aug 2014
                    • 1196
                    • Hellas ( Greece )
                    #29
                    Indeed,what kind of behavior should i expect when i remove the ic?
                    By the way the 8131L ic is hot selling on ebay, seems has problems pretty often.
                    • BlueMidnight
                      • Jan 2015
                      • 489
                      I expect it will do nothing except get rid of the hot spot. But maybe it will miraculously get the 3V/5V rails working. We can always hope. But if it doesn't, then you definitely have more than one problem. And anything that could damaged those two areas could have also damaged a number of other things.
                        ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-12-2024, 03:28 PM
                        ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-12-2024, 02:30 PM
                        ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                        09-06-2024, 05:27 AM
                        ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                        This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
