Packard Bell Easynote TK85/ Acer Aspire 5742 reboot loop
  • Retrocomputer
    • Aug 2012
    • 47
    • Italy
    Hi!
    As I wrote in my presentation I have a few laptops to be repaired, if possible.
    I'm quite a newbie in this topic, so please forgive me if I make some mistakes.
    As in title, I have a Packard Bell Tk85 (which has almost the same guts as the aspire 5742 (at least it surely has the same mobo, a Compal PEW71 LA6285P)
    which shows the following symptoms: as I press the power button, the blue lights show up, the fan starts spinning, and it tries to read from the HDD. after a few seconds, it shuts down and reboots. Nothing is ever shown on screen, at any time. No backlight nor any kind of image. If powered on from the battery, it continues to reboot as in a cycle, if powered from supply, it usually reboots one time and afterwards it stays on, with black screen. The fan works fine, the temperature sensing circuit seems to work well, it turns on and off the fan as the temperature floats. Another symptom is that it as I turn it down with the button, after a few secontds it boots up again.
    Already stripped to the bare board with just ram, cpu, monitor and power button connected, nothing changes. If booted without any ram nothing changes again, no beeps or anything. What might the fault be on the mobo?
    Thank you very much and sorry for my bad English!
    Davide
  • sopik78
    • Nov 2013
    • 519
    • Czech Republic
    Re: Packard Bell Easynote TK85/ Acer Aspire 5742 reboot loop
    First try to read all main voltages when power up if they are correct. Attach schematic here.
    Reflash BIOS and EC as well.
    • Retrocomputer
      • Aug 2012
      • 47
      • Italy
      Here's the schematics for my mobo model. Which voltages should I check?
      For the reflash, I have to wait that the little programmer I bought arrives.
      https://cdn.badcaps-static.com/pdfs/...9ad1b2efd4.pdf
      • Retrocomputer
        • Aug 2012
        • 47
        • Italy
        Which are the BIOS and EC chips?
        Thank you
        • Retrocomputer
          • Aug 2012
          • 47
          • Italy
          I just checked the main voltages. They seems to be perfect, imho.
          +CPU_CORE: (@C272): 1.03V
          +0.75VS (@pin 204 DIMM1): 0.76V
          +1.05VS (@L1): 1.05V
          +1.05VS_VTT (@PJ12): 1.05V
          +1.5V (@pin 5 U24): 1.52V
          +1.5VS (@pin 3 U24): 1.52V
          +1.8VS (@R944): 1.83V (before and after resistance)
          +3VALW (@pin 9 U31 / pin 5 U26): 3.34V
          +3V_LAN (@L99): 3.36V
          +3VS (@pin 3 U26): 3.35V
          +5VALW (@pin 5 U25): 5.03V
          +5VS (@pin 3 U25): 5.03V
          +VSB (@R935): 18.95V before R, 18.43V after R, 19.18 when switched OFF
          +RTCVCC: (@pin 1 D1): 3.05V when ON, 2.75 when OFF
          All voltages seem stable, +3VALW, +3v_LAN, +5VALW, +VSB, +RTCVCC are all present with pc is switched off (S5 state).
          Thank you.
          • Retrocomputer
            • Aug 2012
            • 47
            • Italy
            ... Nobody can help me at least identifying the correct chips?
            BIOS should be U30/31 (in my mobo U30 is unpopulated, U31 is a 1M cFeon chip), but on U18 I have a Winbond 32M chip, what is that? Or is U31 the EC chip and U18 the BIOS?
            Thank you.
            • sopik78
              • Nov 2013
              • 519
              • Czech Republic
              U18, the bigger one - BIOS
              U31, 128kB - EC
              • Retrocomputer
                • Aug 2012
                • 47
                • Italy
                Ok, thank you.
                Waiting for the programmer, here are the voltages on these chips in S5 and full on state.
                S5 (power supply connected, ram installed, nothing else)
                U31 (EC):
                pin1 fluctuating periodically between 3.38 and 2.26 v
                pin2 as above, between 0 and 0.6v
                pin3 3.38v stable
                pin4 gnd
                pin5 0v
                pin6 fluctuating periodically between 0 and 0.37v
                pin7 3.38v stable
                pin8 3.38v stable
                U18
                pin1 0v
                pin2 0v
                pin3 0v
                pin4 gnd
                pin5 0v
                pin6 0v
                pin7 0v
                pin8 0v
                turned on (only ram and cpu installed):
                U31
                1 0.21v stable
                2 0.91v stable
                3 3.37v
                4 gnd
                5 1.48v
                6 0.16v
                7 3.38v
                8 3.38v
                U18
                1 3.38
                2 3.38
                3 3.38
                4 gnd
                5 0
                6 0
                7 3.38
                8 3.38
                Is that of any help?
                The pc continues to reboot by itself.
                • Retrocomputer
                  • Aug 2012
                  • 47
                  • Italy
                  Nothing?
                  Do the voltages "say" something or are they correct?
                  Can I do anything else while my little programmer is being shipped?
                  Do we have the correct bios and ec files to flash? I found something on here by searching with the TK85 keyword, but I can't tell if they're right or not, as there were many versions of TK85 models.
                  Thank you
