Dell Latitude E7440 power LED blink
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Dell Latitude E7440 power LED blink after pressing power button, then power LED, hdd LED, wifi LED blink automaticaly and restarting again and randomly blink.
    No display, fan is turned on during power led blinking.
    Guys please help me.
    Thanks in advance.
    Here is the schematic:
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: Dell Latitude E7440 power LED blink
    Problem solved.
    • bestdan50
      • Aug 2015
      • 170
      • nigeria
      Originally posted by subroto
      Problem solved.
      how did you solved the Problem
      • farooquepm
        • May 2016
        • 10
        • india
        how did you fix this problems
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          By flashing BIOS and replacing RTC battery.
          • kingaarbi
            • Apr 2016
            • 120
            • Malaysia
            Re: Dell Latitude E7440 power off
            when switch on after 20 sec turnd off..and battery led blink for 2,3 sec..
            please advice.
            thanks in advance
              • 21936
              please advice.
              thanks in advance
              Read post 4 and 5 . Replace the cmos battery first,if that doesn`t work flash the bios.
              • kingaarbi
                • Apr 2016
                • 120
                • Malaysia
                i tried both options change cmos and flash bios but still same...
                • kingaarbi
                  • Apr 2016
                  • 120
                  • Malaysia
                  there is no processor volts no ram volts and also no voltage on usb. please advice .
                    • 21936
                    have a look at PU100 ,check for +3.3V_ALWP and +5V_ALWP
                    • kingaarbi
                      • Apr 2016
                      • 120
                      • Malaysia
                      thanks alot for advice ... both voltages are ok..
                      any other thing
                        • 21936
                        Ok, check voltage on PU100 pin 3 ,U43 pin 14 +3.3V_ALW_PCH and PL701 pin 1
                        • kingaarbi
                          • Apr 2016
                          • 120
                          • Malaysia
                          thanks again brother... these all voltages are ok..
                          but i noticed on u46 input 3 and 5 voltages ok but output voltages no have..
                            • 21936
                            U46 needs the RUN_ON signal from the KBC. Next check PU300 pin3 and 8
                            • AwaisMinhas
                              • Dec 2020
                              • 7
                              • Pakistan
                              I have dell 5440 with same fault kindly help me
                              • zaheer118
                                • Feb 2016
                                • 14
                                • pakistan
                                no voltage pin numbr 3 and pin 8
                                • nguyentuong3790
                                  • Jul 2022
                                  • viet nam
                                  Dell 5440 have source 19v q124 3v q126 but do not on the screen? thank!
                                  • hoarderteks_kyriakos
                                    Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
                                    by hoarderteks_kyriakos
                                    Hello.
                                    Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
                                    Here is what happened:
                                    At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
                                    10-08-2025, 07:33 AM
                                  • dlonely94
                                    Dell Latitude 5591 not power on
                                    by dlonely94
                                    Hi everyone!
                                    I have a Dell Latitude 5591. It has a strange problem:
                                    First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
                                    When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
                                    But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
                                    Sometime, when it not power on, I just unplugged the battery and adapter, wait...
                                    10-13-2024, 10:29 AM
                                  • imedbox
                                    Dell Latitude 5440 no power on
                                    by imedbox
                                    ihave the same probleme the labtop want charge with the power supply! my bat is decharged then i can test it with battry it power on!
                                    i got this after flash bios "XM25QH256C" for removing admin password,i revert to the original then not charge or power on, befor it power on and chargin!
                                    Any Help !
                                    her link for Boardview and the Schematic
                                    Dell Latitude 5440
                                    bios version : 1.12.20
                                    MTHERBOARD : IDB40 LA-M401P Rev:1.0(A00) 2023-11-10
                                    https://www.transfernow.net/dl/20250721QpvcJ0UG
                                    07-21-2025, 03:03 AM
                                  • NADJIB
                                    Dell Latitude 7390 _DAZ20 LA-F312P 1.0 - all power rails up except VCC_CORE and VCC_GT
                                    by NADJIB
                                    I need help please​
                                    I have Dell Latitude 7390, LA-F312P 1.0
                                    - power LED turns on a few one second or two withe power supply or battery
                                    - the power supply indicate current 0.16 A While laptop is powered
                                    I checked:
                                    While laptop is powered from battery/barrel plug AND power LED is on, all voltage rails show up, except +VCC_CORE and +VCC_GT.
                                    * COIL
                                    PL612
                                    - Output resistance to ground is 14.7 ohm.
                                    PL613 AND PL610
                                    - Output resistance to ground is 9.8 ohm.
                                    01-23-2024, 04:31 PM
                                  • Tynan Dill
                                    by Tynan Dill
                                    Assuming...
                                    11-22-2024, 01:46 PM
