Sony Vaio inverter input pin layout
  • lefos
    • Nov 2013
    • 321
    • Greece
    I am working on a Sony VAIO which doesn't have backlight.
    Tried other inverter / panel with no success.
    It has a 6 pins inverter on which I measure only 19V
    Can you please tell me its voltage layout? I think that the 2 first pins are 19V (which I have them) and the 2 last have to be 0 right? I have the 4 pins with 0 voltage unfortunately.
    Thank you
  • Djosla
    • Dec 2012
    • 246
    • Montenegro
    Re: Sony Vaio inverter input pin layout
    Take a good picture of inverter input,from both sides and post...first two pins are usually 19v and last two ground,and two in the middle are invertor enable an dimming pin which require about 3,3-5v, 0-3v(for non-inverted) respectively...Don`t apply this info to your invertor before checking thoroughly...you could damage your board...
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      Be aware, don't try other inverter if you don't know the pins, even with the same plug, it's possible to burn some component on motherboard.
      The controller chip on inverter mobo, needs an enable signal.
      Download the datasheet of this chip and find the pin with a tester.
      It's possible to know the inverter pins with a motherboard schematic .
      I solve an issue in a old notebook, the motherboard does not send the enable signal,
      by creating it on inverter board , the lamp lit up. It was not possible however to adjust the brightness
      • lefos
        • Nov 2013
        • 321
        • Greece
        Thank you both for your replies. I am trying to do the same with this one as you, jasko_jacker, I want to find the 2 necessary voltages for enabling the backlight. The thing is that I don't have a VAIO with the same connector in order to "produce" the voltages.
        Do you think that connecting on those 2 pins 3V that it will work?
        • highpulse
          i hate HP
          • May 2013
          • 1490
          • portugal
          does vaios usually have a comparator Ic this comparator is responsable for letting BLon , and outher enbale pins to light up display . bether way is you to tell us the board code , MBX-xxx for we can manage to help you out
          • lefos
            • Nov 2013
            • 321
            • Greece
            Hello there,
            Thanks for your reply. The board is MBX-224.
            • lefos
              • Nov 2013
              • 321
              • Greece
              Hi again,
              I soldered both middle pins to ~3.3Volts and now the laptop has backlight.
              The odd thing is that brightness control is not possible. But no worries.
              Thank you all for your time.
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO VPCM12M1E/W Netbook Specification for Upgrade or Repair
                This specification for the Sony VAIO VPCM12M1E/W Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VAIO VPCM12M1E/W boardview and VAIO VPCM12M1E/W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
                Sony VAIO SV-T1122F4E Hybrid (2-in-1) Tap 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO SV-T1122F4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SV-T1122F4E boardview and SV-T1122F4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
