Dell 3521, 3537 problem
  • laptop market
    • Sep 2012
    • 122
    • mansoura
    Hi
    FIRST 3537
    4 BEEBS
    I PROGRAM BIOS AND CHANGE RAM BUT STILL 2 BEEB
    2ND 3521
    I PROGRAM BIOS AND CHANGE RAM AND REPLACE IC GET HOT IC NO 5616A
    IT GIVE ME 2 BEEB
    IT SHOULD GIVE 5 BEEBS COZ BATTERY IS REMOVED
  • laptop market
    • Sep 2012
    • 122
    • mansoura
    Re: Dell 3521, 3537 problem
    • kavinda
      • Aug 2014
      • 9
      • sri lanka
      replaced new pch
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Calidebear
        Dell 3537 laptop doesn't boot without embedded display.
        by Calidebear
        I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
        So checked the schematics to bypass this issue.
        Found something but I don't know how to read this schematics.
        Dell 3537 mobo 9982p rev 3
        Schematics attached,...
        03-29-2025, 11:37 AM
        Dell Inspiron 3521 15" Laptop Schematic & Board View
        Dell Inspiron 3521 15" Laptop Schematic & Board View...
        10-03-2024, 12:54 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • rddube
        Dell 15-3537 motherboard part identification
        by rddube
        Trying to identify the following part J7 FL M1R in the photo which is on one of the power circuits on a Dell 15-3537 motherboard. Went through the SMD code manual but couldn't find it and google doesn't either.
        Help please and thank you
        02-27-2024, 09:50 PM
