How to Reflash KBC KB9012. :thinking:
  • pravin6p
    • Mar 2014
    • 75
    • india
    HI friends,
    you can flash a KB9012QF KBC Without any special programmer.
    With a normal bios programmer you can flash KB9012QF.
    Find these pins 42, 59, 60, 61, 62.
    with the help of a schematic diagram find these pins on keyboard connector.
    ground pin 42.
    put a dummy bios on the programmer.
    connect PIN 59 to #CS on the programmer.
    PIN 60 to #CLK
    PIN 61 to #SI
    PIN 62 to #SO
    Ignore any errors and warnings from programmer.
    (the programmer may give wrong manufacturer errors)
    give power to the motherboard.( dont switch the motherboard on just connect the adaptor)
    click on the program button on the programmer software.
    and you are done.
    use your brain if got struck somewhere.
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: How to Reflash KBC KB9012.
    good idea, it work really , are you trying this friend ?
    • pravin6p
      • Mar 2014
      • 75
      • india
      I already tried and it worked for me.
      • Djosla
        • Dec 2012
        • 246
        • Montenegro
        What programmer are you using ?
        • rievax_60
          • May 2012
          • 897
          • australia
          This seems relevant, https://www.youtube.com/watch?v=f3WzJZKEZx4
          • pravin6p
            • Mar 2014
            • 75
            • india
            my programmer is SuperPro 600P bios copier.
            • pravin6p
              • Mar 2014
              • 75
              • india
              Originally posted by rievax_60
              ya..
              i got this idea after seeing this video. but he is using a i/o programmer.
              as of my experience i was successful in flashing bios with wrong manufacturer id errors (bios chips which is not listed in my programmer) and i take the advantage of that.
              If any 1 trying it don't forget to ground the programmer with the motherboard.
              And you can only write kbc, reading is not possible !
              • alihomee
                • Dec 2012
                • 1574
                • malaysia
                just change it
                • naeemshahzad
                  • Jan 2015
                  • 129
                  • uae
                  which ic did you select in device
                  • dj_free
                    • Oct 2014
                    • cam pha
                    dummy bios is winbond 25x80 and then select 25x80 on the programer software ok??
                    my english is very bad.tks
                    • bjhawfam
                      • 144
                      Where would the ground be, I have the schematic and all soldered,,,, which pin would be the ground on the programmer? any unused pole?
                      • Teeheeze
                        RT809H Programmer Firmware Corrupted
                        by Teeheeze
                        This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                        02-13-2025, 04:51 PM
                      • H34TO
                        ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                        by H34TO
                        Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                        06-17-2025, 07:17 AM
                      • STKR123
                        The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                        by STKR123
                        Greetings badcaps community,
                        I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                        So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                        Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                        I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                        These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                        I learned that desoldering...
                        10-29-2024, 06:03 AM
                      • vinceroger69
                        TL866CS MiniPro EPROM programmer software
                        by vinceroger69
                        Hi has anyone got the latest software for the TL866CS MiniPro EPROM programmer version 03.2.86 is installed now i have tried the update site in the programmer software but it wont connect to their website i am running windows 10
                        Edit found this site programmer works now http://www.xgecu.com/EN/Index.html
                        09-03-2024, 06:21 AM
                      • EazyBone
                        EMMC programmer questions
                        by EazyBone
                        Looking to up my game a little bit, but these programmers seem a bit daunting.
                        Trying to get a device for EMMC repair, and it's very difficult to lookup all the words to find if I'm on the right track lol.
                        Trying to reprogram EMMC on Sony/Hisense mainly but would like to hit a few other brands.
                        My question is would either of these work? And is there a specific card reader I need for TV emmc? There is like 10-40 additional pieces that I can get but not sure what I actually need for my application only.
                        I may do eeprom as well. Can someone point...
                        04-21-2024, 08:18 AM
