HP 246 Not Power on With Adapter
    HP 246 (6050a2493101-mb-a02) is not power on while connected with Adapter.
    But working with Battery.
    Pls advice where to start
    Thx in advance
    Re: HP 246 Not Power on With Adapter
    measure pins on charging ic
      Bq24728 without battery
      Code:
      pin1(ACN)=0.9v
      pin2(ACP)=0.9
      pin3(CMSRC)=0.9
      pin4(ACDRV)=0.8
      pin5(ACPRES)=3.3
      pin6(ACDET)=2.6
      pin7(IOUT)=0.0
      pin8(SDA)=3.3
      pin9(SDL)=3.3
      pin10(ILIM)=0.1
      pin11(BATDRV)=1.1
      pin12(SRN)=1.1
      pin13(SRP)=1.1
      pin14(GRND)=0v
      pin15(LODRV)=0
      pin16(REGN)=6.1
      pin17(BTST)=5.9
      pin18(HIDRV)=1.1
      pin19(PHASE)=1.1
      pin20(VCC)=19.5
      With Charged battery it is working well. I can't take reading while battery inserted since BQ24728 is under the battery.
      when adapter inserted battery charging indication is Orange LED.
      pls advice
        measure voltage q6011.
          measure voltages q6011.
            All Readings Only With Adapter
            Code:
            [B]Q6011[/B]
            Pin 1 to 3 : 0.9
            Pin 4    : 0.9
            Pin 5 to 8 : 0.9
            [B]Q6010[/B]
            Pin 1 to 3 : 0.9
            Pin 4    : 0.9
            Pin 5 to 8 : 20.3
            [B]Q6012 [/B]
            Pin 1 to 3 : 1.1
            Pin 4    : 1.1
            Pin 5 to 8 : 0.9
            and one more thing C6031 & C6032 caps missing
            C6031 Reading
            Code:
            Pin 1 : 20.3v
            Pin 2 : 0.9
              try to change q6010. or measure q6012,q6011 with battre without charger
                measurement q6012,q6011 with battre without charger
                Code:
                [B]Q6011[/B]
                All Pins : 12.1
                [B]Q6012[/B]
                Pin 1 to 3 : 12.1
                Pin 4    : 18.3
                Pin 5 to 8 : 12.1
                is C6031 Essential ?
                  check pr6017 with battre inserted no charger
                    There is no component mounted in R6017
                    R6017 Reading only With battery
                    Pin 1 : 12.1v
                    Pin 2 : 12.1v
                      change first q6010 second u6000.
                        change q010 then
                          is C6031 Essential or not ?
