Toshiba Satellite L655 : screen blinks !
    Hello everybody !
    I have a Toshiba Satellite L655 with a blinking LED screen : it blinks white, and seems to reboot, like it detects an overconsumption. If I put an exteral screen, it's OK.
    I repaired sooner a bad U6000 on it (with the help of this forum !), is there another problem on it, do you think ?
    Thanks in advance for your help.
    French IT Tech. Pleased to find this good forum
    Re: Toshiba Satellite L655 : screen blinks !
    Hello.
    Did you test with another screen ? The one you have may be defect.
      Thanks for your answer. Yes, I did. Same results with the twos, and they work fine in another laptop.
        The next logical thing is to change the lcd cable.
        But if you got balls of steal test wire by wire and tension the cable at the same time
        You know like opening and closing the.lid.
        P.s. Check the connector.inside
