toshiba l735 with main lvds connected problem on charging ,
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    well got this from another store , mentioning machine was shuting down randomly , after making some measurements all seems fine on the charging circuit .. now the trouble comes here .. if i leave the lvds conneccted , it showed image perfectly , and if its working only with dc jack (without battery works fine) if i insert dc jack plus battery , i turn on machine (turning it on on my power supply of the lab , i notice the 3.2 amp (since its charging battery , after like 10 seconds , power and battery led start blinking in orange , and the power lab show me 0 amp consume .. but still the computer showing image , after a while it will shutdown .
    power led should be white , and it turns white , but start blinking in orange with the led charge as well ,
    NOW .. if i remove the lvds screen and leave only on external screen , there are no issues to report . charges ok , leds stays ok , and no shuting down , O.o ????
    tryed diferente battery ,still the same . tryed a diferent screen , the same .. so on external work fine , if i insert internal screen , it will stay crazy .. anyone had this issue before ?
    i apreciate any feedback
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: toshiba l735 with main lvds connected problem on charging ,
    o notice there is a nec tokin 0D128 ,this could be replaced with what ?
    • highpulse
      i hate HP
      • May 2013
      • 1490
      • portugal
      with 6 470uf 6.3v, but just ordered one nec to replace
      bether with the original
      • sergiormzg
        • Dec 2015
        • 13
        • mexico
        hello, I have ek same problem , only 6 and put 470 uf capacitors and introduces me a blue screen , you have no idea how to fix it ?
        • sergiormzg
          • Dec 2015
          • 13
          • mexico
          I already did , but it shows me blue, green screen.
          change four 330uF tantalum capacitors
          4 tantalum capacitors change
          uf 470
          and shows the same light blue screen.
          You have any idea what it could be .
          the problem was similar to yours, turned off at certain time , but the picture looked good .
          • sergiormzg
            • Dec 2015
            • 13
            • mexico
            I searched capacitor data sheet NecTokin 0D128 and can not find you have no idea of value and voltage uf
            • megaraider
              • Jul 2015
              • 307
              • Portugal
              This is one of the main symptoms exhibited when the NecTokin is faulty.
              There are several models known to be affected:
              TOSHIBA Satellite Axxx and Lxxx series, ACER Aspire 24x0, ASUS ROG, ASUS Rampage, GIGABYTE GTX470, ...
              Despite the exact NecTokin value being unknown almost everyone report being successful after replacing it with:
              4 x 330uf, Low ESR, tantalum capacitors
              ESR must be lower then 0.007 Ohm!
              • sergiormzg
                • Dec 2015
                • 13
                • mexico
                http://imageshack.com/a/img911/7306/li8hgN.jpg
                http://imageshack.com/a/img910/7519/0XwCB2.jpg
                http://imageshack.com/a/img907/9821/NnGynE.jpg
                http://imageshack.com/a/img907/1809/2fuEY0.jpg
                images here
                • sergiormzg
                  • Dec 2015
                  • 13
                  • mexico
                  http://imageshack.com/a/img907/8236/Mh5S7Z.jpg
                  http://imageshack.com/a/img633/6718/Ey92ec.jpg
                  http://imageshack.com/a/img908/8232/F7UG6h.jpg
                  • sergiormzg
                    • Dec 2015
                    • 13
                    • mexico
                    finally I found the flaw , which were some tracks were removed from the motherboard , I just picture a bridge and back to normal .
                    thank you very much to all of you each comment it was of great help to continue the search .
                    greetings and I can help I am to serve .
                    • karim_hassan777
                      • Oct 2015
                      • 15
                      • Egypt
                      thanks a lot for aiding us
                      • semiRocket
                        Toshiba 37bv701b power supply main rails
                        by semiRocket
                        The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                        I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                        Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                        10-26-2025, 01:55 AM
                        09-06-2024, 05:59 AM
                        09-06-2024, 05:33 AM
