macbook pro a1286 no image on internal but ok on external
  • Jse Enrique
    • Feb 2021
    • 38
    • cuba
    #41
    Re: macbook pro a1286 no image on internal but ok on external
    thanks huys
    • Madoy104
      Macbook Pro A1989 - No image, working fine with external monitor
      by Madoy104
      I have a MacBook Pro A1989 that was likely exposed to liquid. It doesn't display an image on the built-in screen, but the screen is backlit (you can't see the Apple logo or any other elements when held up to light). The laptop provides 20V and 1.5-2A, and it works fine when I use it with an external monitor. Currently, the connector for the display (J8500) is disconnected. I'm writing to ask for help in diagnosing the issue. I've heard that when the J8500 is exposed to liquid, the processor pin responsible for the display might short-circuit, and I'd like to know...
      08-15-2024, 10:01 AM
    • fasda1984
      GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died
      by fasda1984
      , Hello have same GS66 Stealth 11UE, it start only in external HDMI monitor, Internal display died without crash or something, just started in black screen, checked driver in devices and have only external display, no more internal... Any suggestion? External working fine, no problems no errors
      06-22-2024, 01:43 AM
    • Ugur87
      MacBook Air M4 A3240 Brand New Water Damage no Image
      by Ugur87
      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
      Yesterday, 01:09 PM
    • baglaivlad
      MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
      by baglaivlad
      Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
      Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
      01-09-2024, 09:55 PM
    • sdogs
      macbook pro M1 a2338 no video on internal display PP3V3_S2 short
      by sdogs
      Greetings to the entire forum, I ask you for help because I'm going crazy. A dear friend of mine gave me a macbook pro M1 A2338 that only works with an external screen. With the internal one, no backlight or image. Only the external display is detected from the system settings.
      First I changed the display flat, then I made a backup with time machine and tried a reset in dfu but nothing to do, always the same problem.
      I analyzed the logic board, it shows no sign of liquid or visible damage. I then moved on to examine the logic with the thermal camera and found that the UP701 chip was...
      06-27-2025, 01:58 PM
