Asus ROG GA401QE (Ryzen 9)- weird issue
  • gurj1979
    • Dec 2014
    • 190
    • Photography, electronics, movies, old skool music (hip hop, RnB, Garage, Jungle etc).
    Hi guys,
    I have pretty much just finished repairing this laptop after 3v rail shorted around 8 components.
    Now I have the machine booted up with all voltages present.
    Display etc etc works, I can get to BIOS without issues.
    BUT - the problem is this.
    Battery connected and is healthy. Wont turn on unless charger is connected.
    Then I can remove the charger and it will continue to run from battery.
    But if I turn off the laptop, it wont boot from battery. Have to stick in the charger again to trigger it.
    All MOSFETs are good, no shorts anywhere.
    Please help.
  • mon2
    • 16656
    Is the power adapter the original OEM and proper rated unit for this laptop?
    The mosfets are still suspects. Remove all power and measure their resistance for a review.
    source / drain
    source / gate
    gate / drain
    Each should be hundreds of k ohms or higher else could be a leaky device.
    • gurj1979
      • Dec 2014
      • 190
      Powers supply / chargers isn't the issue.
      It wont turn on from battery when button is pressed.
      Please read and try to understand the issue first.
      • gurj1979
        • Dec 2014
        • 190
        Resolved myself - 1st replacement ITE KBC chip was a little bad. Swapped out again and works fine.
        BUT - Noticed a different issue.
        I have tried the Armory Crate GPU Power options - but it doesn't help.
        GPU is still not showing up in Device Manager - Show Hidden shows no Nvidia.
        Tried to install Nvidia drivers, but it says there is no Nvidia card detected.
        I'm guessing a power rail missing for this.
        • gurj1979
          • Dec 2014
          • 190
          All Resolved now.
          U7004 had a dry solder at Pin 10 - GPU_RST#
          Laptop working sweet now.
          • Boardview and Schematic Bot
            ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
            This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
            09-07-2024, 01:00 AM
          • lukkihapsi
            Asus Vivobook X515JA Weird Boot Issue
            by lukkihapsi
            Asus Vivobook X515JA Laptop
            Issue :
            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
            Tried :
            Cleaned inside for dust, applied fresh thermal paste. No Change!
            Removed keyboard, Trackpad, fingerprint sensor. No Change!
            Removed Internal SSD. No Change!
            Updated BIOS to latest version. No Change!
            Removed battery and pressing power button for 1 minute. No Change!
            Weird Part :
            Upon turning laptop ON, screen lights up - stays black,
            I...
            07-07-2025, 12:07 PM
          • ezenia
            ASUS ROG STRIX B450-F GAMING REV 1.01 - USB Overcurrent Issue.
            by ezenia
            Bought an ASUS ROG STRIX B450-F GAMING REV 1.01 off eBay. Seller said fault was board wouldn't POST and was stuck on CPU LED (and occasionally VGA/DRAM). When I tested the board, it actually does POST. However, it complains about a USB Overcurrent issue and shuts down in 15 seconds.
            Work has been done on this motherboard already. They removed the audio codec, a chip labelled U31U3 on boardview and some ESD diodes/SOT23's near the USB ports. It appears they tried to resolve this overcurrent issue and weren't successful. I did my usual resistance checks on the 24-pin connector and found...
            06-19-2026, 12:07 PM
          • Stephen
            A2779 MacBook Pro 14" MOST WEIRD ISSUE I HAVE EVER SEEN
            by Stephen
            MacBook Pro 14" A2779 having a no power issue. power raise are ALL HEALTHY! I probed all of them ALL healthy.
            Getting 20volts 4amps battery charging, etc. Disconnected battery to see voltage and amps. Getting 20volts 0.135amps-0.139 with no battery connected. Disconnected trackpad to see what the fans would do, they go into full blast, odd behavior, plugged into an LCD external nothing displays, ok...this is freaking weird, going down this rabbit hole I keep trying everything. I even went out of my way and tested a working battery I had in stock at the store. LIKE Nope nothing same...
            04-21-2026, 11:32 AM
          • bajdik
            Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
            by bajdik
            I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
            Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
            I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
            Unfortunately, I don’t have access to the schematic.
            It seems to me that when I bend the board, something changes.
            Could this...
            08-13-2025, 07:26 AM
