[help]lenovo thinkpad 16s gen 2 TOTALLY DEAD
  • phantomEVO
    • Mar 2013
    • 509
    Hi to all! thinkpad p16s gen 2 totaly dead. i have only 5v on both ports.
    pd controller is tps65994
    i don't know where to start: could you help me? thank
    Schematic & Boardview - https://www.badcaps.net/forum/troubl...atic-boardview
  • reformatt
    • Feb 2020
    • 1536
    This has a NVDC power supply, so should boost the USB-C 5V to around the battery voltage. So first thing to check is for a short on the B+ rail, then presence of your +3V LDO. 20V negotiation is irrelevant.
    • phantomEVO
      • Mar 2013
      • 509
      hi reformat thank you for your answer...
      i don't know what is a nvdc power supply
      battery has very very low voltage
      on the pd controller i have
      5v ON DOCK_VBUS20
      0v on Vin3,3
      5v on Charger in
      3,3v on Vcc3 Ldo
      now what can i check?
      Thank you
      • mon2
        • Dec 2019
        • 14735
        https://forum.monolithicpower.com/t/...power-path/162
        • phantomEVO
          • Mar 2013
          • 509
          Thank you...so ..what could be the next step?
          • mon2
            • Dec 2019
            • 14735
            0v on Vin3,3
            ?? Suggest to use the exact netname from the schematics otherwise it becomes a game of 'Where is Waldo?'. Our PCB designer does the same often and we have to spend time to hunt for the new label created in his head.
            Where was the above measured?
            To me, if the Vbus voltage is not 20V then there is something wrong with the PD controller. The PD controller is often a stand alone negotiator for the power delivery contracts. Provided the firmware is ok and the pd controller is not defective, the Vbus rail should be @ 20v, supplied by the power adapter.
            Any power rail that is @ 0v or not in the normal range, test its resistance to ground (without power to the board) to check if the rail is shorted or not.
            • phantomEVO
              • Mar 2013
              • 509
              all measurements done on pd controller no shorts on the pd controller
              with vin3,3 i mean vin_3v3
              • mon2
                • Dec 2019
                • 14735
                This is of concern since the rail is also used by the PCH (CPU).
                Remove all power. Meter in resistance mode. Measure the resistance to ground of VIN_3V3. Checking if there is a shorted part on this rail. What is the exact resistance in ohms?
                • phantomEVO
                  • Mar 2013
                  • 509
                  25k
                  • phantomEVO
                    • Mar 2013
                    • 509
                    even with another pd controller, i have the same behaviour
                    • phantomEVO
                      • Mar 2013
                      • 509
                      ok i0ve disconered something .... i have short on pl5301
                      i've removed the coil and the short is on the right side (pin 1)
                      this side is connected to 2 mosfet and charger ic....now??
                      removing mosfet pq5302 the short is gone...should i replace it? its is an n-channel 30v 85a mosfet...should i mount the same identical?
                      • reformatt
                        • Feb 2020
                        • 1536
                        This is a buck/boost converter power supply. You will get 5V on USB-C initially, then it will be in boost mode to get your B+ voltage (which should be around the same voltage as marked on the battery, and not +19V). The PD controllers will only negotiate 20V once you have some ancillary power rails come up. But for that you need the main power supply to be working and providing B+. When you get 20V, then the power supply goes into buck mode and reduces the voltage to that of the battery.
                        All of this is in Piernov's sticky at the top of the forum BTW and some troubleshooting steps.
                        https://www.badcaps.net/forum/troubl...arging-circuit
                        You haven't mentioned what the B+ voltage is, if any. Very rare for these MOSFET's to fail.
                        • phantomEVO
                          • Mar 2013
                          • 509
                          thank you for your amazing explaination i tought it would work like macbook!
                          for "b+" you mean the voltage of the battery? or the voltage of the battery measured on board while charging?
                          • reformatt
                            • Feb 2020
                            • 1536
                            Mac's work similar. As I said, 20V is irrelevant as a starting point in these designs with a buck/boost converter.
                            Are you even looking at the schematic? B+ is the main power rail. Should be around the same as what the battery voltage is. 12V or so.
                            Just had a dead Lenovo on the bench. No current draw at all. Just needed batteries removed, along with the CMOS battery. So just needed a BIOS reset, so make sure you cover the simple stuff first.
                            • phantomEVO
                              • Mar 2013
                              • 509
                              thank you for your amazing reply!!!
                              i'm starting to understand how it works...a little bit complicated for me...but i'm trying to understand.
                              but why don't you take attention to what i have found?
                              short on pl5301: following the path, i have removed a mosfet (pq5302) and the short is gone...now my problem is to replace it. it is 30v@70a!!!!
                              do you think that this mosfet could be the reason of the main problem?
                              • phantomEVO
                                • Mar 2013
                                • 509
                                so, i've temporaly replaced the mosfet with a irf3205
                                https://www.alldatasheet.com/datashe...F/IRF3205.html
                                connected the charger only i have had charging led
                                so i have installed the battery, and press the power button
                                i have seen white led from the power button,then suddenly i have heard my power supply "switching" and notebook power off itself (ive seen that my power supply was set to 20v 1,1a, so i have think to connect it's original power supply (19v 3,25a) but nothing.
                                no charging light, no 19v on amp meter , nothing. motherboard dead like before.
                                the shorted path where i have changed the mosfet, is not shorted
                                  Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                  This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                  09-06-2024, 11:40 AM
