Lenovo 730-15IWL No energy
  • dagolard
    • Sep 2025
    • 9
    • Schweiz
    Hi everyone.
    I have a Lenovo Yoga, where the charging doesn't work.
    - No charging/Battery LED, even with battery disconnected
    - power supply is tested and okay (65W and 135W version tested)
    - onboard fuse PF202 is okay
    - until cable I can measure the voltage (Clip22 removed, measured the wires).
    If I press power button, a little "click" sound from speaker appeares. Seems he want to start, but not enaugh battery.
    I think it is the FET PQ302 (see picture). Looks a little... defective in one corner.
    Can anyone tell me what type it is?
    How can I check, if it is that part?
    Regards Holger
    Redacted because of horrible english
  • mon2
    • Dec 2019
    • 14995
    Pour some ipa (alcohol) onto the part. This will enhance the topside markings. Share a good pic or all markings. Then google should help to find a datasheet for this component. This mosfet will be an n-channel or p-channel mosfet.
    To test if the part is ok or not, remove all power. Meter in resistance mode.
    Measure the resistance across the mosfet.
    Source (1-2-3) & drain (5-6-7-8)
    source & gate (4)
    gate & drain
    pick a pin from each group. Post each measurement in ohms.
    • dagolard
      • Sep 2025
      • 9
      • Schweiz
      Okay. Will do it in evening.
      • mon2
        • Dec 2019
        • 14995
        NVM. I think I found the schematic and have the details for PQ302.
        PQ302 is an N-channel mosfet. This implies that the gate pin must be higher than the voltage being passed between the source & drain pins. This part is acting like a solid-state relay / switch and will fully enable if the gate voltage is ~25v (since adapter voltage is ~19v).
        Do perform the resistance checks as above (without power to the board!!). This will allow us to confirm if the mosfet is defective or not. Repeat with the 2nd DCin mosfet. Often, it is the 2nd DCin mosfet that is defective. If either of these mosfets is defective, the defective mosfet will stop the other one from working as well because they are sharing the gate (driver) pins.
        Do review the charger bible as per the sticky above by @piernov.
        Post your measurements when convenient.
        • dagolard
          • Sep 2025
          • 9
          • Schweiz
          Source-Drain: 1.1R
          Source-gate: 2.1R
          Gate-Drain: 2.4R
          • mon2
            • Dec 2019
            • 14995
            Post the details of your meter face for the above measurements. Is the meter an automatic scaling type or manual select version?
            1.1R = 1.1 ohms?
            Better if you post a pic of the meter face to show one of the above measurements.
            • dagolard
              • Sep 2025
              • 9
              • Schweiz
              R is Ohms. Sorry, sometimes we are used this naming in the industry.
              I always cleaned up my workpace. It is a automatic scaling multimeter (see photo). Not the newest, but not bad at all.
              • mon2
                • Dec 2019
                • 14995
                The meter is auto-scaling. Take a pic of one of the measurements so we can confirm if you are truly @ 1R1 = 1.1 ohms which is a serious short. Suspecting you are not - check the top right corner of the LCD to note the units of measurement.
                • dagolard
                  • Sep 2025
                  • 9
                  • Schweiz
                  Guys, maybe I´m not good at newer high integrated electronics (I´m 62 and learned the electronics job in 1982) but I can read a multimeter. 😉
                  The difference (1.3 ohms) probably depends on a little shakey fingers while measuring AND make the picture with two hands only. Was between 1.1 and 1.2 most time.
                  • dagolard
                    • Sep 2025
                    • 9
                    • Schweiz
                    So it looks like I have to get a EMB04N03H. 🤔
                    Will look on monday in our company. Maybe there are some in the "assortment drawer" of our electronic engineers left over from older projects.
                    • mon2
                      • Dec 2019
                      • 14995
                      This part is shorted. Flux and remove the part. Then repeat the testing with the part on your work bench. Very likely the part will remain with low resistance = defective.
                      Repeat testing with the next dcin mosfet. It may also be defective.
                      • mon2
                        • Dec 2019
                        • 14995
                        The part can be replaced with many others. Check almost any motherboard for n-channel mosfets of the same physical size.
                        • dagolard
                          • Sep 2025
                          • 9
                          • Schweiz
                          Thanks. As long actually my main pc too has problems (my RTX 4070 super has massive VRAM problems) the prioritys have changed. But good to know where I have to look.
                          If I have news I will tell here. 👍
                          • coasterghost
                            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                            by coasterghost
                            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                            System Hardware:
                            Processor: AMD Ryzen 7 PRO 5850U
                            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                            09-08-2025, 10:46 PM
                            Lenovo 3000 Series Schematic
                            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                            3000 C100 laptop with Braille keyboard
                            Lenovo 3000 C
                            C100, C200 - 15-inch XGA screen
                            Lenovo 3000 N
                            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                            N500 - 15.4 inch screen.
                            Lenovo 3000 V
                            V100, V200 - 12.1-inch WXGA models
                            Lenovo 3000 G
                            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                            10-04-2024, 06:05 AM
                            Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                            This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                            09-06-2024, 06:40 AM
                            This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                            09-06-2024, 06:06 AM
                          • derradji89
                            Need help Lenovo MIX 320-10lCR domaine name SERCOL
                            by derradji89
                            Hi everyone 🤗
                            I have a Lenovo MIX 320-10lCR computer.**
                            1. **Operating System**: Windows 10 ** Education** 64-bit.
                            2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                            3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                            4. **BIOS Chip Reflashing**: Currently,...
                            04-19-2025, 03:04 PM
