Trying to disconnect shorted GPU on my Acer Predator 17 G9-793-73A6 (N15P4)
    Hi, I am trying to bring back to life my Predator without the shorted GPU (bought in 2017).
    For now I don't have schematics, my mainboard is far not similar to others I found here, all mosfet are 7658A part one RA10.
    Each coils have 2 or 3 mosfets, so I removed coils, still shorted on GPU side 0.2ohms.
    But still not enough, It begin to start, as soon I see hdd led and hear some noise from hdd it restart.
    Here some picture of the board
    https://youtu.be/tMUdAhtZk_g?si=0ph58aw6QR4JJKik
    The other side
      Click image for larger version  Name:	IMG_0372.jpg Views:	3 Size:	1.29 MB ID:	3653941
      Oh looking with the microscope the down side of the board I noticed something weird !
        I have doubts about your diagnose to be honest, since 0.2 Ohms are nothing to worry about in the GPU Core section. These are normal values. But it also needs to understand about what GPU related power rails we are talking here in particular. the one with the 3 Phases is most likely the Core, but what is the one with the single inductor? Here you are possibly right and it most likely isn't okay anymore to measure 0.2 Ohms there. Unfortunately the schematics and the pdf boardview doesn't reveal it for some reason. The only thing I know now is that the coil got the designation PL9700 from the designers.
        And it would be a big advantage when you tell something about the (previous) symptoms of the device, whether the CapsLock test was performed, things like that. Before you started to mess with the board.
        FairRepair on YouTube
          And yes, this pin needs to be bent back, since it won't make proper contact anymore to the internal display.
            Humm really interesting thank you!
            So I went back to take the measurement with more precision, my owon oscillates between 0.10-0.12 ohms
            This laptop is back from Acer repair service, diagnosis gpu dead, the entire mainboard needs to be replaced.
            So now I realize I made a mistake, I went straight in that direction!
            At first, it didn't power up, just some flashing of the battery LED.
            Later, I realized that by removing the battery connector, it goes further, I got the current state ( video on Youtube).
            If you still think this value of 0.11 can be considered normal, I think it's could be better I go back.
              I tried but this pin seems to be broken (pin37).
              In this schematic from another, more recent version, but it probably hasn't changed for this connector, there's an inconsistency between the schematic and the table on the right.
              According to the table on the right, this would concern the camera, which isn't my priority at the moment, but in the schematic, it would be a +5VS_LGF, which could be more problematic.
              Click image for larger version  Name:	IMG_0373.jpg Views:	0 Size:	1.02 MB ID:	3654197
                Only the schematics to the left applies. What you see on the right is imho how it connects to the panel after the cable.
                  It's just needs to be visualized what connects to where. So instead of to measuring between ACN and ACP directly you can measure between these two points.
                    Sorry I don't know what you're talking about ?
                      I'm back to the beginning.
                      With the battery connected, the battery LED only flashes and nothing else (this laptop has been inactive for 2 years, so I think it's dead).
                      If I disconnect it, I have the sequence on video: 2-3 times, and it turns off.
                      I noted the voltages on each coil.
                      5V is the only one present as soon as the charger is connected.
                        Updated with processor, measured on capacitor, I think mosfet and coil are on the other side
                          Yep, "slipped" into the wrong thread. Sorry....
                            Sephir0th or of course anyone else.
                            I'm really surprised it refuses to start if the battery is dead.
                            Especially since it's not a removable battery!
                            At this point, do you think a disconnected battery could have an impact on the failure to start?
                            What do you think about voltages measured (last picture) ?
                            Thank you for your time
                              It can't power up with the battery being disconnected? Sounds strange
                              However, the voltages you shared are looking fine. So it could be something simple. I would try removing the SSD and reseat the RAM, and try with only one RAM module installed at time. Tey excluding one of the module and one of the slots being faulty this way.
