Dell Latitude 5310 2 in 1 Laptop does not power on, shorted capacitor replaced but not solved
  • im_trying
    • May 2025
    • 14
    • Italy
    Laptop does not power on but has a fix white light on power button, when connected to power.
    I found, while trying to diagnose, a hot spot in the motherboard and found it to be a shorted capacitor (see photo below) on the 2.5v (2D5V_S3 on schematics). After replacing it with one from a donor board, still, the board does not turn on...
    The usb-c meter reads upon connection 20.1v and 0.00a, with some occasional flashes to 0.03amps. After 10/15 seconds circa, it goes to 5.2v and draws an almost constant 0.07amps. (same behaviour as before)
    To my fingers, nothing seems hot (I don't have a thermal camera). I do however have a bench power supply, if injecting voltage can find the culprit.
    Thanks in advance
  • kakazu
    • May 2025
    • 4
    • Philippines
    try to check the mostfet main power
    • im_trying
      • May 2025
      • 14
      • Italy
      It is getting through both mosfets of dc-in, it measures 20v when the usb-c sends 20v. And 5v when it sends 5v.
      The 3.3v coil and the 5v coil are both present.
      All measurements are taken with the motherbard out and nothing attached.
      I just noted that with the battery attached, sometimes the white led on the power button doesn't turn on, even though all the coils have the same voltages.
      • kakazu
        • May 2025
        • 4
        • Philippines
        Try to check if power IC is good if not replace it
        • im_trying
          • May 2025
          • 14
          • Italy
          I don't know how to do that exactly... Still a newbie, but im trying. Should I check for any pin in particular on the chip? Like LDO?
          • im_trying
            • May 2025
            • 14
            • Italy
            I checked the the LDO I found in the schematics, which there are two. A 1.8v near the PD controller, and a 1.2v on the other side of the board. The 1.8v is present, the 1.2v is not. I guess we're making progress but I don't really know how to procede. Is it a bad EC chip? A bad BIOS for the EC chip?
            • ammaoui
              • Mar 2015
              • Morocco
              Please provide me the value of these two resistors near the bios chip
              post moved...
              • peste
                • Dec 2016
                • 13585
                • ROMANIA
                post moved...
                post , full name and model, motherboard model, etc.
                  DELL Latitude 5310 Notebook 5000 Specification for Upgrade or Repair
                  This specification for the DELL Latitude 5310 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5310 boardview and 5310 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5310...
                  09-06-2024, 08:40 PM
                  09-06-2024, 08:10 PM
