Dell Inspiron 6400 can't turn on
  • gianttora
    • May 2014
    • 17
    • Malaysia
    I got Dell Inspiron 6400 from my friend. This laptop can't turn on. When i connected this motherboard to dc power supply it shows that voltage is decreasing and current is increasing. CC indicator also light up, so i think there is a short circuit on this motherboard.
    One more thing is, fet (PQ6) is heating up so fast and extremely very hot. So i try to change the fet but the result still the same. Anybody can help me to solve this problem.
  • gianttora
    • May 2014
    • 17
    • Malaysia
    Re: Dell Inspiron 6400 can't turn on
    Anyone please help
    • dj_ricoh
      • 2073
      short on board!
      did you took the board out?
      pictures!
      find the first fets test them
      • gianttora
        • May 2014
        • 17
        • Malaysia
        Thanks for reply,
        Here is the pic of the DC regulated power supply which showing motherboard is short. My friend told when the voltage value is decrease, the current is increase and CC led is light there is short circuit on the motherboard.
        And here is the pic of the motherboard where u can see the fet (PQ6).
        Actually i'm not really sure how to test this fet. Should i connect this board to power supply and then test it. As I mentioned before when this board is connected to power supply this fet will become extremely hot in a short of time. I afraid it will burnt the fet and board too. So how do I test this fet in a right and proper way?
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          check fets near dc jack
          https://cdn.badcaps-static.com/pdfs/...0f957c212b.pdf
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            check PQ42, PQ28, PQ22, PC144, PC145
            • sasser
              • Dec 2012
              • 364
              • Malaysia
              any caps around PQ6 was shorted . any caps when touch your finger hot?
              • gianttora
                • May 2014
                • 17
                • Malaysia
                Actually i'm not really sure how to test this fet. Should i connect this board to power supply and then test it. As I mentioned before when this board is connected to power supply this fet (PQ6) will become extremely hot in a short of time. I afraid it will burnt the fet and board too. So how do I test this all the component above in a right and proper way?
                • gianttora
                  • May 2014
                  • 17
                  • Malaysia
                  I am not sure which one. I can feel nearby caps is getting hot but cannot specify which is it.
                  Can i take out fet PQ6 from motherboard and do the voltage test. What voltage value should i get when test it ?
                  • sasser
                    • Dec 2012
                    • 364
                    • Malaysia
                    wait be patient. u must trace from leakage cap maybe around there. im not sure but when i face with this case my PSU Lab read increase up to 5.0Amp and im sure some caps was leak. so try to find out and test again pq6 is hot or not. if not try replce the caps
                    • gianttora
                      • May 2014
                      • 17
                      • Malaysia
                      So u mean i need to find which caps was leak on this laptop motherboard and then clean them properly? Ok i'll try to find them.
                      • SteveHart
                        • Mar 2012
                        • 11
                        • Indonesia
                        First thing you must do is to lower the current limit. Ussualy 1A is enough. After that you can search the component that is shorted by lightly touching the components directly connected to the 19v rails and find the one that becomes very hot. That component is the culprit. FETs, diodes, and caps are the most likely
                        • gianttora
                          • May 2014
                          • 17
                          • Malaysia
                          I unable checking all the components u listed above because i afraid the mobo and fet (PQ6) will burnt. When connected this fet getting extremely hot within a couple of second.
                          • gianttora
                            • May 2014
                            • 17
                            • Malaysia
                            I can't find any leak caps but when i remove PQ6 and connected the mobo to power supply here is the result i get.
                            Now no more components become too hot after i remove PQ6.
                            • gianttora
                              • May 2014
                              • 17
                              • Malaysia
                              Sir do you mean that i need to tune mannualy the Regulated DC Power Supply current value from 3.94A (pls refer pic in first post) to 1A. I already did that and found FET (PQ6) become extremely very hot just within a couple of second.
                              • dj_ricoh
                                • 2073
                                if you replace the fet and still have the same problem you got a short on the board.
                                a cap its more likely because when you remove that fet you took out the rail so it wont be short.
                                this is a good thing if you plan to go forward like go to the next component and try to power until you find the broken part
                                • gianttora
                                  • May 2014
                                  • 17
                                  • Malaysia
                                  Thank you sir for replying. Do i need to test the next component without resolder the fet back? What voltage should i get when test the other component?
                                  • gianttora
                                    • May 2014
                                    • 17
                                    • Malaysia
                                    When i look at the circuit diagram, I found a couple of component near the FET. I got FL2, PC22, PC20, PR16, PR21. I already did a voltage measurement without resolder the FET (PQ6) back. Here is the result.
                                    FL2 - 18.95v, 18.95v
                                    PC22 - 18.95v, 0.00v
                                    PC20 - 5.59v, 18.95v
                                    PR16 - 5.59v, 18.95v
                                    PR21 - 0.00v, 5.59v
                                    I also tested FET (PQ6) on motherboard
                                    Pin 1 to Pin 3 - 18.95v
                                    Pin 4 - 5.59v
                                    Pin 5 to Pin 8 - 0.00v
                                    So which one is the culprit ..?
                                    • gianttora
                                      • May 2014
                                      • 17
                                      • Malaysia
                                      PR21 - 0.00v, 5.59v
                                      Pin 4 - 5.59v
                                      Sorry i'm not testing the mosfet. I just test the mosfet point on the motherboard.
                                      • SteveHart
                                        • Mar 2012
                                        • 11
                                        • Indonesia
                                        Yes, you should manually adjust the current. The reason that I ask you to limit the current to 1A is to avoid the FET (PQ6) getting too hot and broken while you search for the shorted component.
                                        As dj_ricoh said, if you take out the FET, you just simply take out the 19V rail. Hence there will be no current flows to the rest of the circuit. So if the FET is measured OK outside the circuit, you can put it back in the circuit, and do the power supply test once again. This time try to find other components that becomes hot. That one is the culprit.
                                          DELL Inspiron 3650 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 02:15 PM
                                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                          09-12-2024, 03:44 PM
                                          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
