acer travelmate p214 status "charging" but battery percentage not increasing...0mW charge rate
  • dqtech
    Badcaps
    • Jul 2018
    • 630
    • N/A
    early problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
    i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
    schematic/boardview link - https://www.badcaps.net/forum/troubl...baco-schematic
  • mon2
    • Dec 2019
    • 14250
    Locate the dual diode PD9002. Remove all power. Disconnect the battery. Meter in DIODE mode.
    Test this dual diode. Red meter probe on pin #2. Black meter probe on pin #3. Meter should conduct with a voltage.
    Reverse the meter probes, the meter should block with 'OL'. Repeat with pins #1 and #3. Post each measurement.
    • dqtech
      Badcaps
      • Jul 2018
      • 630
      • N/A
      hi sir mon2...here the measurement
      Red meter probe on pin #2. Black meter probe on pin #3 = 0.262v
      Red meter probe on pin #3. Black meter probe on pin #2 = OL
      Red meter probe on pin #1. Black meter probe on pin #3 = 0.262v
      Red meter probe on pin #3. Black meter probe on pin #1 = OL
      • mon2
        • Dec 2019
        • 14250
        This dual diode is OK and not reverse leaking. On some cases, have seen this part cause 'fake charging' conditions.
        Measure the voltage to ground of:
        ACDET ; should be 2v7 or higher
        ACOK ; should be a logic '1'
        REGN ; should be ~6v
        ACDRV ; should be ~25v to enable the 2 x N-channel DCin mosfets
        with the adapter & battery connected.
        • dqtech
          Badcaps
          • Jul 2018
          • 630
          • N/A
          mon2 here the measurement with battery & adapter connected sir..
          ACDET ; 4.44v
          ACOK ; 2.99v
          REGN ; 0v
          ACDRV ; 0v
          • dqtech
            Badcaps
            • Jul 2018
            • 630
            • N/A
            and after few minutes all voltage on that pin become 0v
            • dqtech
              Badcaps
              • Jul 2018
              • 630
              • N/A
              i try re-connect adapter again and all voltage is normal like this...after few seconds its getting 0v
              • dqtech
                Badcaps
                • Jul 2018
                • 630
                • N/A
                i dint do anything....right now its charging normally..why this happen?
                • mon2
                  • Dec 2019
                  • 14250
                  Suspecting something borderline ok but could it be an old battery? Continue to test.
                  • dqtech
                    Badcaps
                    • Jul 2018
                    • 630
                    • N/A
                    now i test with old and new battery...i charge until its full...because customer said before no power issue (short 19v), the old battery drain so fast...i check using batmon apps that old battery capacity is okay, design capacity and full charge capacity is the same
                    • dqtech
                      Badcaps
                      • Jul 2018
                      • 630
                      • N/A
                      discharge rate is around 4300-4600mW per second when idle...is that normal sir mon2
                      • mon2
                        • Dec 2019
                        • 14250
                        Hmm. Honestly do not know but you can test with the unit only on battery after a full charge. Google for the expected life of the unit if powered only by battery. Keep in mind that battery life capacity will decrease over the life of the battery itself so the time will decrease over time.
                          Acer TravelMate P214-53-53NF Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-53-53NF Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-53-53NF boardview and P214-53-53NF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-07-2024, 05:20 AM
                          Acer TravelMate P214-53-583U Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-53-583U Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-53-583U boardview and P214-53-583U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-07-2024, 03:40 AM
                          Acer TravelMate P214-41-G2-R5EB Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-41-G2-R5EB Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-41-G2-R5EB boardview and P214-41-G2-R5EB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          Acer TravelMate P214-53-593J Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-53-593J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-53-593J boardview and P214-53-593J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          Acer TravelMate P214-53-74PM Notebook P2 Specification for Upgrade or Repair
                          This specification for the Acer TravelMate P214-53-74PM Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-53-74PM boardview and P214-53-74PM schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
